Question about Garden
I went to turn on my gas grill and opened the valve to the propane tank which is indicating "full". Although when I turn the knob(s) to start the grill no propane travels trough the hoses???
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 327 Answers
Its probably not the hoses its probably your burner are clogged with drippings and need to be replaced or just move the lava rocks of off them and tap on the burners the dispense the propane, try that.
Posted on Jul 20, 2010
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Full tank but no gas smell and just bought a new hose and regulator
follow this steps and fix it. God bless you
Test the propane tank valve for leaks:
  1. Turn the grill control knobs on the front (and, on some models, the side) of the barbecue to the off position.
  2. Turn the propane tank valve fully counterclockwise to close it.
  3. Mix a test solution of equal parts of dishwashing liquid and water in a small container.
  4. To test for leaks, apply the test solution liberally to the connection between the regulator fitting and the tank valve using a small paint brush. Apply the test solution to the valve handle and threads, the length of the hose, and the connection between the hose and the regulator. If bubbles appear at any point, there is a gas leak.
  5. Tighten the connections and retest.
  6. If you still see bubbles at any of the tested connections, close the tank valve and replace the leaking component.
Test the hose fittings for leaks:
  1. With the tank valve open, brush the test solution on the fitting at the other end of the hose, located under the control knobs.
  2. Turn the control knob to high and test the hose and fittings leading from the control knob to the grill. Turn the right control knob to off. Repeat the process for the other control knobs.
  3. If you see any bubbles during any of these tests, close the tank valve and contact your propane dealer or your local gas utility. Do not use the barbecue until the leak is corrected
Oct 29, 2013 | Weber Genesis Silver A Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Genesis Silver B Grill
I cannot get the gas grill to light. The tank was not completely empty but I replaced it anyway to make sure that was not the problem. I have the same problem with the refill. It does not seem to be...
the regulator could have gone into lock up.
try this to unlock it...
  1. Open the BBQ Lid
  2. Turn ALL main control knobs to the "OFF"/CLOSED position
  3. Turn the Propane tank valve to the "OFF"/CLOSED position
  4. Disconnect the Regulator hose from the Propane tank
  5. Turn ALL main control knobs to the "ON"/OPEN position
  6. Let stand for 1-2 minutes, allowing all excess gas in valves and manifold to dissipate
  7. Turn ALL control knob back to the "OFF"/CLOSED position
  8. Reconnect the regulator hose to the Propane tank- hand tighten only.
  9. Check all hose connections to ensure that a positive seal has been made
  10. SLOWLY turn "ON"/OPEN the propane gas supply
  11. Wait approximately 5 seconds for the regulator pressure to stabilize
  12. Turn "ON"/OPEN the selected burner control knob to "HI"
  13. Press the Multi Spark ignition button or match light selected burner.
  14. Hope this helps you has me in the past!
Jan 08, 2018 | Char-Broil 463220004 Grill
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
Can't light the bbq
You make have turned the propane tank valve on too fast. Close the valve, disconnect it, reconnect it and very slowly turn the tank valve back on. That should solve your problem.
May 31, 2010 | Weber Genesis E-310 Gas Grill
Propane gas flame is not hot. Do I adjust the air
Here is something to try if it is LP Gas:
Here is a Tip to fix a grill that not getting hot:
1. Turn the gas valve knob off. then close LP tank valve knob.
2. Unscrew the plastic hose coupling knob from the LP tank. You may hear a slight "hissing" sound as pressure is released this is normal.
3.Wait a minute then screw the coupling knob back on to LP Tank.
4.With lid open.slowly open LP tank valve.
5.Relight the grill the proper way by turning gas valve knob to ON position while turning the igniter knob at the same time.
6.After you are sure the grill is lit preheat the grill for 30 minutes.
This was called purging the line or releasing the air out of the line.
Another thing your orifice could be clogged with spiders or dirt. If it is LP gas check to make sure your hose is not kinked.
Mar 23, 2010 | Ducane Affinity 3100
My weber gas grill suddenly does not heat up enough. It has been working for two years and suddenly the amount of flame is tooooooo small to cook.
Hello. You may not have enough propane left in the tank for it to work properly, you may not have turned the tank valve to the full open position, or your valve safety device may have kicked in. IF this last item is what happened read on:
  • turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank.
  • Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders.
  • Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released.
  • Leave the grill, side burner, rotisserie, etc on high for a few minutes with the hood open before turning all the valves back to the off position.
  • Make sure. Most gas barbeque grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the “on” position.
  • With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
  • Slowly. The trick here is to turn the hand wheel slowly.
When the propane gas tank is new or newly-filled, the gas is full and the OPD is pushing slightly on the top filled area and the gas will want to burst through the valve. Slow it down by turning the valve on slowly and the check valve will reset itself.
Regards, Joe PS please rate my answer. Thank you.
Jan 16, 2010 | Grilling
Can't hear the gas
If the tank has been in storage for the winter, it may be empty.....If it is a new tank. turn the tank off, disconnect and reconnect the gas line, turn on the tank, depress and turn the control knob on the grill and attempt to light. Another thought is that if you used a tank exchange to get a full tank, they may have inadvertently given you a empty tank for your turn in tank.
let me know what you find.
clarkco
Apr 29, 2009 | Char-Broil Quickset Traditional 463761006...
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
