Question about ASUS P5LD2-VM Motherboard
P5LD2-VM replaced Power Supply and now won't boot.
Now switches off right after starting IDE Scan.
  • 1 more comment
  • Anonymous Apr 30, 2008
    It worked for 2 weeks and now it will not post. All of the fans are going, the hard drive was tested in another pc and its good, changed the power supply, checked the memory, still no post.
  • Tiger_ted May 01, 2008
    found the problem by accident, PC worked when on its side!!!
    Turned out to be a loose heat sink on the CPU.
  • hasdf May 11, 2010
    Is it sending a picture to the monitor? Can you access the BIOS?
    Champion:
  • 254 Answers
Clear the cmos battery by removing or switching and wait 1 hour then try again
hope this helps
Posted on Jan 05, 2009
Unable to use S-ATA on Asus P5LD2-VM
in the BIOS set the SATA controller to IDE this should fix the problem. And try with AHCI selected.
Apr 16, 2013 | ASUS P5LD2-VM Motherboard
Sometime it start and sometime it does'nt start. plz gv me d solution.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 30, 2010 | ASUS P5LD2-VM Motherboard
Will Asus p5ld2-vm SE MOTHERBOARD support 1 tera-byte hard disk? i hav 2gb ram
Yes it should. The issue is not so much with the motherboard supporting the hard drive. It is more the question of whether or not the power supply will support the power required to run it along with all of the other additions.
Jan 03, 2010 | ASUS P5LD2-VM Motherboard
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Our system has an IDE drive that runs the machine but i have just connected a new sata drive and the machine does not see it, motherboard - ASUS P5L02-VM and hardrive - Seagate 1.5TB
Did you switch the pins in the back of the new drive from master to slave? If you have them set both to master, you might have conflict. good luck
Sep 03, 2009 | ASUS P5LD2-VM Motherboard
My cpu dont see new hdd wd5000avvs ,motherboard Asus P5LD2 SE. i trying omost everything. help;/
are you using ide or sata connection? if your using sata conection between your motherboard and harddrive, you must enable it in your bios, just reboot your pc and keep pressing F2 while its booting to prompt your bios. There you can look for IDE/SATA configuration. After enabling your sata, save any changes before you exit and reboot... Just give it a try...
Jun 22, 2009 | ASUS P5LD2-VM Motherboard
ASUS P5LD2 Raid 5 locks windows at MUP.SYS
A stab in the dark. Sound like the MB BIOS expects and is written to have the OS on the  IDE  slot. After that I would add one SATA drive at a time to see if it matters and to see if one of the drives are causing the problem.
Jan 05, 2009 | ASUS P5LD2-VM Motherboard
ASUS P5LD2-VM Chassis Intrude
Do you mean the pins for the chassis intrusion on the board are broken off?
if not broken then just jumper them and bypass the switch.
Jan 26, 2008 | ASUS P5LD2-VM Motherboard
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
ASUS P5LD2-VM Motherboard Logo
435 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
