Question about Frigidaire Freezer 16.7 cu. ft. Upright Freezer
Not freezing equally
The freezer freezes on the bottom shelf but the upper shelves do not freeze. Seems like the bottom works and the upper doesn't
  • 1 more comment
  • Anonymous Nov 30, 2008
    not freezin on bottom shelf
  • Anonymous Mar 13, 2014
    i have aeg arctis freezer and it frezes top two shelf with loads of ice where as bottom two dosent freeze ar all. alos how can I slow down the freezing. thanks
  • Anonymous Mar 16, 2014
    model FFU17D9CW1. Top shelf freezes. Bottom shelves won't freeze. Compressor is running. Door seals seem to be ok.
  • 145 Answers
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Posted on Apr 23, 2008
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Jan 05, 2015 | Electrolux Freezers
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Top shelf not freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Apr 27, 2010 | Freezers
Bottom 2 shelves not freezing
if it does not freeze it is because the refrigeration system is low on freon. this will cause the bottom shelfs to not freeze...
you have to decide if it is worth putting the freon back in (they wont fix it because very hard to find)
so you could spend anywhere from $80 to $150 to get the freon back in... then after a while it will leaks out and you will have the same problem
why dont you instead move that money to a new freezer
hope this was helpful
Mar 04, 2010 | Freezers
Frost Buildup on Top Shelf lower shelves aren't freezing
This link might help you troubleshoot
Freezer Frost inside Symptom Diagnosis Sears PartsDirect
The lucky solution is if the door seal or inner plastic liner need to be placed/repaired (this lets warmer air into the freezer causing frost and poor cooling).
But you can also see from the link that your symptoms could be caused by other electronic related things...more of a challenge to fix...
Good luck on your troubleshooting
Feb 17, 2018 | Frigidaire Freezers
Rack on freezer is not working
low on freon. buy new . as freon level drops , ability to feed all shelves falls off. the last shelf to freeze is usually the first one to not freeze ,as charge goes away. time for new, cost to fix to great.
Nov 22, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore Upright 13 cu.ft freezer- uneven freezing
no it sound like there is a problem with the seal system where the freon is kept this model does not have a fan because is the shelves get frosted so there is a leak or restriction so try calling a tech but i would just buy a new if i was you since to fix will cost about the same
Nov 08, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Upright freezer.Two shelves freeze up. One doesn't. Why and is this a problem
look to see if the shelves are in fact not shelves but evaporator coils . if the shelf is connected to small tubing, then that tubing flows freon that freezes the shelf. if its clearly not connect to any tubing or piping then its just a shelf and gets residual cold from evaporator shelves. if it is connected to tubing like the others and not getting cold then you have whats called a restriction. . particles have plugged the tubing and no freon is feeding the shelf. if that is happening then consider having a pro recover the gas , unplug the tubing , replace the drier and recharge it. if its an older unit and you are getting by then maybe not worth the expense.
Nov 01, 2008 | Kenmore Freezers
Freezers Logo
490 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
