Question about Frigidaire Affinity ATF7000E Front Load Washer
Washer has e20 code - Frigidaire Affinity ATF7000E Front Load Washer
  • 4 more comments
  • Anonymous Jun 21, 2008
    e20 message
  • ssgtpepper Sep 24, 2008
    1. My washer does not do the second spin cycle. It stops and gives error message E-20. I would like to know if there is a service bulliten or any recalls on some of the parts. this is a 2006 model and I am not very happy that I have to buy parts so soon. I thought I was getting top of the line.
  • courtsavnich Dec 30, 2008
    I am having this same E20 error message. My laundry will go thru all cycles until it reaches the spin cycle. Once it stops and gives the error message, I have to hit cancel and put the washer into the "Spin Only" cycle to complete my laundry. What is the problem??? I have only had my washer for 1 year. Does anyone have a solution to this problem??
  • Tammy Randy Jan 18, 2009
    I have the problem of the washer going through the whole cycle and when it gets to spin it will not spin out the water. I have only had this washer less than a year.
  • kathyhgill Feb 12, 2009
    my washier will not spin or go into rinse cycle
  • eric bosman
    eric bosman May 11, 2010
    model number? and brand?
CLARIFICATION OF THE SIMPLETONS (LIKE ME) OUT THERE... It appears that everyone is correct. The outlet is indeed clogged, resulting in the e20 code. The most likely culprit is the primary reservoir: a black rubber catch found just below the clothes bin. It is mounted to the bin via two hoses - large and small - and secured by hose clamps. The catch is best accessed from the BOTTOM of the washer. That's right - you'll have to lay the washer on its side. I found that RIGHT SIDE DOWN was best. There is a large oval hole in the bottom of the washer; you should be able to see the black rubber catch easily. Detach the larger hose from the bin by loosening the screw-type hose clamp. Then, carefully raise the catch toward you to look inside it (a flashlight helps here). By doing this, you should be able to remove most foreign objects and remove any major clog. It was completely successful for me today... removed my wife's bra pad and several coins which were causing the washer to stop at the initiation of the spin cycle. After re-assembly, I placed the washer upright, connected all the hoses and plug it in... it worked perfectly! I ran it through a couple rinse/spin cycles to remove the remaining lint and minor debris. And, more importantly, I respectfully "urged" the wife to avoid placing such things in the washer in the future! Good luck everyone. This process should only take you about half an hour if you have plenty of space to work, like I did.
Posted on Jul 14, 2010
  • Gahanna23 Jul 16, 2010
    A couple clarifications to my previous post...
    I have an ATF6000FS model.
    I ended up having to place the washer LEFT SIDE DOWN to get the smaller hose reconnected to the bin. In fact, the green factory hose clamp was so difficult to put back on, I bought some 1-3/4" radiator screw-type hose clamps from AutoZone... they worked great and, in case this happens again, will be easy to remove.
    Looking back, I really only needed to place the washer on its RIGHT SIDE (as I had done initially) and ONLY disconnected the LARGER 4-INCH HOSE connected directly to the bin. Because the rubber catch is flexible, it's easy to bend this hose toward you (looking through the oval hole) and - using a flashlight - clean out and unclog. Plus, it's the easiest hose to access, remove and replace.
    By the way, as other have mentioned, don't forget to place a small bowl to catch excess water when you first remove the catch. It's a considerable amount of water and can potentially damage some of the electronics and/or impeller.
    GOOD LUCK!!!
Thank you for the information here, it was a big help. Has anyone else found out that the front of the machine has a lower panel that can be removed and access this job without even moving machine! The hose clamps also require some patience, but all in all - success!
Posted on Oct 26, 2010
After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Posted on Jan 02, 2009
  • 5 Answers
This code came up after we noticed the washer was not draining. I found the filter was full of stuff like a Blockbuster Video Card, a lot of coins and lint. I pulled the washer out and vacuumed the water out with my shop vac, I laid it on it's left side. I started to remove the back panel and then realized the filter can be accessed through the oval hole in the bottom. Remove the drain hose that comes from the pump, have your vacuum ready. Then remove the large black rubber boot that connects the tub to the pump. This is where the filter is, pull the hard plastic filter out through the large hole of the black rubber boot. This is where I found the card and all the other stuff. Clean the filter and reassemble. This should take care of the draining issue and the code will go away on its own.
P.S. careful with the sharp edges on the sheets metal.
Posted on Apr 22, 2009
The e20 is a drain problem my washer would show the e20 code and would not spin i found a clog in my hose right before the water pump there is a litle cup in the black hose that was full of suff after emptying the cup it seems to work good hope this will help you out
Posted on Jan 30, 2009
Checked pipes for blockage.
Checked both pumps-found an elastic band wrapped round the empeller -have removed it seems to have solve the problem
Posted on May 27, 2008
Had the same problem this evening. Turned out to be a hair grip stuck in the impeller motor on the drain pump. Sucking at the outlet with a wet vac would not have done anything, except to wedge this more firmly in place. Glad I didn't try that.
Posted on Aug 19, 2010
  • 4 Answers
Rather than going right at disassembling the washer, try taking a shop vac to the drain pipe. This will force water through filter and then pump and should take care of most problems. The filter catch is poorly designed and can clog easily--even with heavy lint or pet hair. This is why people will see problems after about a year of ownership...those coins and hair knots can build up. The pump is very well designed with a large opening and exit, with a large "spin" area that should handle hair and even coins with no problem, so don't worry about damaging the pump.
Posted on Dec 09, 2009
    New Friend:
My husband was gone for the day so I decided to try to fix it myself since most of the posts said "easy fix". I followed everyone's directions and problem solved! The washer was a little heavy for me to tip on its side but a pile if laundry on the floor helped cushion the fall. Three quarters and a wrapper later, I'm ready to finish laundry.
Posted on Aug 30, 2014
Mine also wouldnt drain. I turned it onto its right side as advised, took off the drain. I couldn't get the black rubber boot off completely, but I could reach my fingers in far enough to pullout the pad from my daughter's swim top. No wonder they say to hand wash. Wash machine is now successfully washing and draining a load of towels. Yippee!
Posted on Nov 16, 2011
Just ran into this issue myself. Found this post and followed Gahanna23's instructions above.
Placing the washer on the right side worked the best and as also mentioned the green factory spring clamp took abit to put back on.. If I had a few radiator clams I would have used them myself..
All and all the job took about 30mins. Follow Gahanna23's post and you should have no issues.
Posted on Aug 25, 2011
2 Suggested Answers
  • 1294 Answers
SOURCE: my washer wont spin out it has a code that is E20
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 12, 2008
What do i do when my washer affinity frigidaire displays E20
Hello friend, thank you for your post!
I see your question is labeled under Frigidaire washer, ATF6000ES, and your washer is receiving an error code of "E20". "E20" stands for the water is not pumping out fast enough which means it could be an issue with your control panel or drain pump. I would recommend having a professional come out and properly repair your appliance. I hope this is helpful. -Matt
Sep 27, 2014 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
Error code E20 on a AEG washer dryer
Ok if its only bring the E20 up on the drying side then this will be a blocked dryer condenser chamber.
To get at this you need to take the back half of the washer off and from there you will see a big plastic chamber going from the bottom up to the top.
Take this chamber off and give it a good clean out with a hose pipe.
Once this is clear refit it and the dryer should be back to normal from there.
Oct 14, 2012 | Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Error code E20
Hello there
the Dreaded E20 fault is a drain problem
washer will show the E20 code and may not spin.
So i would first look for a clog in the hose right before the water pump there is a little cup in the black hose that could be full of suff if so empty the cup and it should work good after this
Best regards Michael
Dec 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
E20 code. Not draining
E20 is a general error code to get to the real problem try this..
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Error Code E20
e20 is a draining issue.check your filter is clean.if this is ok suspect a bloackage in the waste hose or faulty or jammed drain pump impellor
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
3,378 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
