Question about Amana ARB2217CSL Bottom Freezer Refrigerator
Bottom freezer frosted 3"thick
I have an Amana model ARB2217CSL refrigerator with bottom freezer. The freezer is closed but when opened had frosted over everywhere. There is now some ice forming as well. Perhaps the temperature is too cold. If so, how do I turn it down> How do I fix the problem/do I need a repair person...will this hurt my refrigerator????
  • Amana Master
  • 1,769 Answers
Either door seal is bad letting air in or it's a defrost problem
Posted on Nov 16, 2017
    Master:
  • Amana Master
  • 691 Answers
Here is the user manual. Go to page 11 for temperature adjustments.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%2012642722.pdf
catriver
  • 878 Answers
SOURCE: Amana bottom freezer/ refrigerator
Geezer, sounds like a defrost issue. I usually find the bi-metal to be the culprit on this model. Check out the pic. You will have to remove the back panel in the freezer and defrost the evaporator. Remove the ice maker if there is one. The back cover has 4 quarter inch screws. remove those. The air vent has 2 plastic clips one each side and one on the bottom, push in and pull the grill off. The thermistor cover has a slot for a flat blade screw driver,push in and pull the cover off. The thermistor will now slide behind the back panel. Check the bi-metal for buldging. As long as the evaporator fan is working, it's probably a defrost problem.
Posted on Jul 16, 2007
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
woodchuck789
  • 4070 Answers
SOURCE: Frost forms on top of food in my freezer
This excess frosting can be caused by leaky door gaskets, frequent door opening, dispenser door not closing good, anywhere air can get in. Gaskets should hold a dollar bill sung all the way around both doors.
Posted on Sep 24, 2009
  • 9 Answers
SOURCE: freezer frost not defrosting Amana ARB2217CSL
you must put a flash bang in the freezer
Posted on Dec 20, 2009
  • 3 Answers
SOURCE: Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Posted on Jun 05, 2010
I have an Amana ARB2217CSL. The freezer is working fine, but the refrigerator section is no longer staying cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 09, 2011 | Amana ARB2217CSL Bottom Freezer...
Back wall frosting up
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice/frost on it. And you said you had frost on the back wall, you may notice the refrigerator getting warmer.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Amana ARB2217CSL Bottom Freezer...
How do i reverse the refrigerator door of an amana arb2217csl
you canot reverse the handles on this model. There are no predrilled holes or covering plugs on the opposite side. The model number ends in an "l" signifying left hinges. The companion model ends in an "r" with hinges on the right. These fridges were designed so you could purchase them as a pair seting them side by side.
Oct 09, 2010 | Amana ARB2217CSL Bottom Freezer...
Frost buildup
you need to check the defrost circuit and make sure the heater is working and the unit goes into the defrost mode.
also check and make sure the temp sensor is good
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
if you have thick frost on the back wall of your freezer, then your unit is not defrosting. it will be due to a faulty defrost heater, a bad bimetal thermostat, or a bad defrost control.
Mar 19, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
I have an Amana refrigerator, bottom freezer, model # ARB2107 AW, MFG:PHR2107AWO This afternoon, we noticed a burning - electrical type smell coming from behind the refrigerator; more specifically from...
Yes the motor should be running and need to be replace to keep the food from spoiling, this will correct the problem however the buning smell is unknown
Melvin
St Louis
Oct 04, 2009 | Amana ARB2217CSL Bottom Freezer...
Frost forms on top of food in my freezer (top of refrigerator)...even inside sealed bags of items like microwave Stouffer's, etc. Sometimes up to 1/4" thick! No frost on inside of freezer though. ?????
Sep 24, 2009 | Amana ABB1927DE Bottom Freezer...
Refrig is not cooling
. The most common problem is a bad start relay on the compressor. In rare cases the compressor may be bad. If you are mechanically inclined you can replace the relay yourself for less than 50 dollars. You will need model and serial number off of the unit and order the part by those numbers. if the compressor is bad you will need to hire a good service company
Jul 01, 2009 | Amana ARB2217CSL Bottom Freezer...
Amana refrigerator only not working
Few questions first. 1.  What is the entire model # on the sticker inside the fridge section?  2.  Is the fan in the freezer running?  3.  Is there a thick frost build up on the back panel in the freezer (look at the bottom half for a side by side)?
Oct 20, 2007 | Refrigerators
Amana ARB2217CSL Bottom Freezer Refrigerator Logo
47 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
