Question about KitchenAid KESC307 Electric Kitchen Range
The dual burner on my Kitchenaid Superba stove is not working
The dual burner on my cerantop Kitchenaid Superba stove is not working. When you turn it on the smal burner setting, the whole element heats up.
  • 27 Answers
SOURCE: stove burner over heating on low setting
the element only does what it's told. more than likely the contacts in the switch are stuck. the switch needs to be replaced.
Posted on Nov 01, 2007
jsrock516
  • 5911 Answers
SOURCE: Dual cooking zone burner not working
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at repairclinic.com for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
Posted on Sep 09, 2008
SOURCE: Kitchenaid superba Stove Door
I have the same problem, my is frigidaire.
Posted on Sep 12, 2008
  • 415 Answers
SOURCE: Kitchenaid Superba gas stove. Oven
so you get an error message on the display?
do the burners work?
Posted on Sep 13, 2008
craigjamesbt
  • 65 Answers
SOURCE: stove burners won't ignoite
just to be clear I am assuming that you can in fact see a spark traveling from the ignitor to the metal surface over where the gas should be expelled... that being the case you must remove the the gas burner from the stove and check for damage or sign of deterioration ie: cracks, rust holes, missing sections etc. more than likely if there is no damage after 7 years of use the problem will be in the form of carbon and rust deposits inside the burner pieces or associated piping (pipe that are in the burning side of the system don't tear into the gas side) *NOTE THIS WILL NOT KEEP GAS FROM COMING OUT BUT MAY PREVENT IT FROM EXITING IN THE PROPER PLACES DESIGNED FOR LIGHTING* you can clean these carbon deposits by tipping the open end face down and tapping the burner pieces with a block of wood or similar device. These deposits should fall out as a heavy black or reddish brown dust you can also try vacuuming it and running an appropriately size drill bit through each of the burner holes to clean them as well or you can probably just purchase a new one by ordering it from the place you bought the stove
Posted on Apr 26, 2009
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
How to unlock a kitchenaid superba stove
How-To Unlock A Kitchenaid Superba Oven - YouTube
? 1:24
www.youtube.com/watch?v=yKNGTVCEiuM
Sep 22, 2014 - Uploaded by Public Relations & Promotions
How-To Unlock A Kitchenaid Superba Oven ... Repair - Deadoven after self clean mode, blank display, locked door Kitchen
Sep 09, 2015 | KitchenAid Kitchen Ranges
Kitchenaid superba gas stove left front burner will not operate unless back left burner is turned on at same time
The switch for that particular burner is bad. It turns out that whenever you switch on 1 burner, they all spark - that's a safety feature. Depending on the model, you may just need to replace the 1 switch, but usually, they are part of a switch string, and you have to replaced the whole string of switches..
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 19, 2014 | Kitchen Ranges
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
Kitchenaid superba stove baking element does not heat
There has to be a baking element. Find it and replace it.
Aug 19, 2017 | KitchenAid Kitchen Aid Superba Series...
Kitchenaid superba oven
It is very possible that moisture from the cleaning has caused the ignition switches to make enough resistance to cause the burners to spark. It usually goes away after the stove has dried out. If it continues after a day or so one or more of the ignitor switches may need replacing.
Nov 20, 2013 | Ovens
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
KitchenAid KESC307 Electric Kitchen Range Logo
541 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
