My trekstor 160gb external hard drive starts up as normal (spinning)for a few seconds then slows down to a halt with a clunking noise inside,thanks, dave.
  • rocket1960 Jul 21, 2010
    exellent and fast answer, thanks,
    rocket.
  • 4,281 Answers
For that you need to fix bad sectors on harddrive.
You can fix it with disk checkig tools or formating.
Formating is best first take all data backup of harddrive to computer then format it then it will work fine.
And for disk checking right click on drive icon then click on tools then disk check enable recover errors then it will work fine.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 20, 2010
  • 3 more comments
  • rocket1960 Jul 20, 2010
    thanks for your quick answer, but the hdd. will not spin long enough for the pc. to see it, also i forgot to mention that i needed to test another 12 volt dc adapter from something else, so i used my ex. hdd. to test it but just for a few seconds, and with the original trekstor adapter being an unusual shape i am now thinking i could of blown something,thanks,rocket.
  • Check your harddrive with another power adapter and another power outlet.
    if it show power on and still if it not recognized in computer then follow below .
    First make sure usb cable connected to harddrive is working fine.
    try it in different usb ports.
    Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
    then check.
    Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
    And remove upper filter and lower filter.Then restart computer then check.
    If your harddrive still not recognized and still it is not show power on then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
    If it will not work with another power adapter and power outlet then you need to repair harddrive.
    thanks again for your reply, i have tried another 12 volt supply, also i have tested is the original trekstor adapter on my multimeter and its ok., also when i removed the hdd. from its plastic shell i found that the 12 volt feed plugged in to a small circuit board that plugged in to the hdd. which is a sata; is it possible that this circuit board is faulty,also is it a normal thing that when a hdd. loses power it makes a clunking noise inside as it slows to a halt within 3 seconds.
    can the data be recovered if the hdd. will not spin, thanks, rocket.
  • Yes Data is still possible to recover for that take it to harddrive service center first they start harddrive mechanism then they can recover data with recovery software.
  • Yes it is possible to recvover data.Your harddrive mechanism is not working right now so you need to take it to harddrive service center then they first start harddrive mechanism then they can recover data with recovery software.
My Maxtor external hdd switches on, tries to start (spins etc) then switches off within a few seconds
Does the noise sound like a clicking noise at regular intervals?
If so, I'm afraid it sounds like the hard drive is dead and needs to be replaced.
May 20, 2012 | Maxtor Computers & Internet
My hard drive had always worked, but recently it hasn't been recognized by my computers. I believe this is a power issue - the LED powers on then off quickly as a flip the on/off switch. However, the...
Your brief description actually makes me think that the drive itself has been damaged. I have discovered both internal and external hard drives will shut down like this when there are problems with it. Bumps or abrupt movement while the dirve is spinning could be enough to cause damage, and external drives are prone to more of this type of activity. You mention the drive is vibrating, and I would assume that it is more vibration than you would normally notice? Would it by chance happen to be a type of clunking sound? Or do you think it is just the normal vibration of spin up and spin down?
Aug 14, 2011 | Iomega Prestige 500 GB USB 20 Hard Drive
I have a trekstor hard disk ,model number-MSMTU EM s 8,and it is not getting recognized by computer
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 14, 2011 | Trekstor 88570 MovieStation maxi t.u 1TB...
I have a Trekstor 160gb external hard drive just stoppede working. I can hear a very loud rattling noise how do i fix it. Please help
If it's making rattling noises, it's failing (or failed). The only repair is a new drive.
Sorry for the bad news...hope that's helpful, however.
Jan 12, 2011 | Trekstor DataStation maxi m.u SATA 3.5"...
I have Trekstor Datastation maxi 160Gb hard drive, I dropped it, making a terrible clicking noise, laptop or telly won't see it when plugged in, trying to remove casing, took 3 screws a long bottom, can't...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 08, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
My external hd blue light just flashes and i dont have access.
Do you connect via USB or firewire? Can you / have you tried another connection method?
Does it sound like the disk is spinning normally, or is it making a heap of clunking noises or not spinning?
The most common problem (assuming it has power, which it obviously does because it has a blue light), is the USB cable. Do you have another that you can try?
Let us know how you go with that and we'll continue...
Apr 27, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Harddrive space problem.
When the HDD was fornatted, was it formatted appropriately? It's quite possible to format a 160GB HDD to present a smaller amount of space.
Mar 08, 2009 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
TrekStor 160gb Harddrive wont turn on
Try to turn it off and quickly turn it on again in a split second.
And buy a second hard disk just in case.
Sep 28, 2008 | Trekstor (21202) 160 GB USB 2.0 Hard Drive
Non detectable external self powered 40 GB USB Portable Hard Disk
Id recommend trying these following steps: Go to: Start - Control panel - Administrative tools - Computer management - Disk management. Here you should be able to see the 40GB hard drive. Depending on your situation you may need to create a partition, to do so right click the unallocated space and choose to create a partition. The default settings will be fine. Good luck!
Aug 23, 2007 | Seagate 160GB 3.5" External USB Drive 160...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
