Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Hitachi 50UX19K I moved my TV slightly and now it's like the vertical and horizontal hold is off. The picture is not centered?
  • 78 Answers
In the tv menu or on the front of the tv there is an adjustment to align the color guns ( there are three, red blue and green). it will come up as a black screen with a color cross in the center. while this may clear up your problem the cross doesn't always clear it up completely. if the set is really old you might consider a new one.
Posted on May 02, 2008
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
I have what appears to be shadowing of the words.. and picture.. blue wave across the top of picture..
Your Convergence ICs are likely failing. It is very common on rear projections. The solution is to replace the STK chips, check fuses and the resistors next to the STK chips. Replace as necessary and re-align via the service menu. It is about a $300 repair at a tv service center. You will need the service manual if you decide to do this yourself.
Try This:
When you notice the symptons Use this simple test to verify.
Go to the users menu on the tv.
Look for the converge option probably under setup or video setting. Converge is short for convergence to align the red and blue colors to the green color.
If you cannot move the red either horizontal or vertical, then the STK chip has failed for red section.
If you cannot move the blue either horizontal or vertical, then the STK chip has failed for the blue section.
If you can move both in each direction then the problem is something else.
Note if one STK chip fails, you replace both regardless. They will be right next to each other.
Feb 20, 2011 | Hitachi 57SWX20B 57" Rear Projection...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Hitachi 51SWX20B Convergence problem
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Hitachi 60 in rear projection tv
If the picture is jumping from top to bottom this is a vertical issue. The common cause on older Hitacjis is loose connections on the vertical output IC.
Jan 28, 2007 | Hitachi 60EX01B 60" Rear Projection...
No picture
A loose conection in the vertical circuit is likely,call someone to look for it and resoldered it.
Sep 09, 2006 | Hitachi 32UX01S TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
204 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
