Posted on Apr 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IMAGECLASS CANON 6530 - NEW CARTRIDGE (ORIGINAL) PAPER COMES OUT BLANK
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on May 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
455
Points
6
There is a shutter on the laser scanner that is opened when you insert the cartridge.(not the one on the cartridge). There is a mechanism that breaks or bends when the cartridge is inserted to hard or quick. it is a design flaw. I am a technician and have repaired this problem several times. I dont recommend trying to remove this shutter if you are not mechanical inclined!
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Apr 22, 2008
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
950654
Points
10742
Go here. Type "paper comes out blank" in the search window and click Search. Select "printout is blank" and review the steps for replacing the toner cartridge, especially about removing the seals (steps 7 through 9).
Printer won't print after clearing a paper jam
I use to have an HP All-In-One Laser Jet printer that, for reasons unknown to me, wouldn't print after clearing a paper jam until I replaced the ink cartridge.
5helpful
2answers
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
12helpful
ImageClass 6530 copies and prints blank pages.
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
Broken paper drawer for Canon imageclass 6530
You can easily get that from any computer accessories dealer or shop and you can get it in a computer warehouse too. If you can't then you can go to canon online to see if you can get the product from them.
Copies blank
This is normally the corrona wire that needs to be replaced in the transfer unit and drum unit.
1helpful
2answers
Blank vertical streaks
the toner cartridge is running low on toner and it needs to be replaced
Copier does blanks, moves paper, nothing on it.
ayou have a problem to charge and transfer/separator coronas unit.
Image classD661 blank copy
If you just changed the toner cartridge, you probably forgot to remove the metal foil seal, from the side of the new toner cartridge.
k24674
ADMIN Andrew
ADMIN Andrew
