Question about Garden
I just replaced my pool pump motor and after getting it reconnected I am having to turn the pump on with the breaker. The manual switch with the intermatic timer is not working at all. What do you think?
  • 1,368 Answers
THE MOTOR MUST BE HOOKED UP TO THE LOAD SIDE OF THE TIMER AND THE 2 WHITE WIRES MUST GO TO LINE(THEY SUPPLY THE POWER TO THE TIMERS CLOCK MOTOR) OR IT MAY HAVE BURNT THE CONTACTS OF THE TIMER.. YOU CAN SEE IF YOU CAN BREAK THEM FREE AND SAND THEM DOWN. WAA LAA .. COOL FIX OR IT MIGHT BE YOUR TIMER MOTOR HAS GONE BAD, THERE IS A WINDOW YOU CAN LOOK THREW TO SEE THE GEARS TURNING(TOP RIGHT) OF TIMER.. IF THE TIMER MOTOR IS BAD ? THERE IS A GUY SELLING INTERMATIC Timer MOTOR CHEAP ON EBAY YOU WILL NEED TO KNOW WHAT VOLTAGE YOU HAVE.. IF'N I WAS HELP.. VOTE OR COMENT. ..THNX JAY
Posted on Jul 20, 2010
Where are the fuses located on the t40004r
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html#T40000
http://waterheatertimer.org/How-to-wire-Intermatic-control-centers.html
Breakers are usually located in the control panel
Push breaker fully OFF and then fully on
Check that breaker voltage is same as motor... for example if breaker is supplying 240V to pump, but pup is set up for 120Volt, then pump will not work.
Use override switch on timer to see if you can manually start the pump
Check that timer dial rotates ... 1 full turn for each 24 hours
Gene
Sep 01, 2014 | Intermatic T40004R - Pool-Spa Control...
Pool pump won't turn on
check filter breaker if ok check switch or clock if ok see if voltage to pump if voltage bad motor replace pump
Oct 13, 2012 | Hayward Pool & Spa
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
Spa keeps tripping breaker shows pr
two main reasons breaker trips is the pump motor jammed [not turning]or the heater shorted out --disconnect power open access panel disconnect the lines to the heater turn on power if breaker trips than motor /pump problem if doesnt trip than heater problem can order heater replacement online or pool spa store--if motor pump check pump for debris and motor for lube if u can turn shaft or impeller oil motor and work it into bearings if still not turning possible need to replace motor unit
Apr 26, 2010 | Heritage Pool & Spa
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I...
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Sep 06, 2009 | Hayward Pool Products Hayward Max-Flo 1...
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
