Question about Sony Audio Players & Recorders
Remove a CD
How do I get a CD out
  • Sony Master
  • 17,130 Answers
It all depends on what has happened to your player. If stuck within without any power, repair the power supply before you get this out. If the mechanism had jammed due to a badd cd then slowly turn the motor drive to eject. If motor mechanism if faulty reset, if motor drive is fautly check for voltage and replace the drive. Sometime resetting of the set can make the struck cd released. Since I am not told of your make model and exact fault , I cannot give more details. Hope you get this right. Good day
Posted on Jul 20, 2010
How to remove cd stuck in player
Remove cd player and insert small tool to release stuck cd. Otherwise dissassemble cd player and remove.
Take to audio store and have them reome the cd.
Mar 20, 2015 | Jeep 2006 COMMANDER Radio a1z115973...
Cd has fallen behind disk tray and drawer won't close
Remove the metal case/top from the whole unit. See screws at back and any at sides. You should then be able to see and remove the CD upwards, without removing the drawer.
Dec 14, 2013 | Yamaha Audio Players & Recorders
I have a 2005 Ford 500. I have twoo CD"S stuck in the player. How do I remove them?
If the two cd's which are stuck, if you can see that cd's then pull the cd with pliers.Its a two mouth pliers to pull the things out.The cd may get cracked/ break while removing.But if the cd's are not seen or its very hard stuck, then in that case.The cd player has to be removed out of dash.Yes it will be time consuming, and will not be very simple.But once the player is out, its not much to do.The cd player bottom has few screws to be removed.Once you remove the screws, the complete top assembly will get lifted.You can say" complete casing" will be lifted.Once the casing is out.You will visually see the cd, and you can manually slide the cd out and remove it.---------- ---------- Click this link for cd player removing procedure from dash :--------- http://whoisbyme.blogspot.com/2011/08/how-to-remove-cd-player-from-dash-of.html ----------- This will help.Thanks.Helpmech.
Aug 03, 2011 | Ford Five Hundred Cars & Trucks
Remove cd player/2003 toyota avalon xls
hi,
please state the problem completely sir.What is it that you want to do?
Jul 19, 2011 | Car Audio & Video
I have a suzuki 2007 grand vitara the cd is stuck in the cd player how do i remove it
You need to remove the radio/cd player from the dashboard and open the CD player to get the CD out.
You can remove the whole front panel. 6 screws at each side underneath the alu xxxxx must be removed. After this the whole panel can be mover forward and the connectors on the backside can be disconnected. Now you are ready for opening the radio/cd player. tahe of the top cover and remove the cd
Jan 01, 2011 | 2007 Suzuki Grand Vitara 4WD
Cd is stuck it says error 4, how do you remove
Sometimes the jammed CD can be removed by teasing it out using another (old) CD.It requires patience...but it does work
Otherwise the player will have to be removed from the dashboard, the metal covers removed and the jammed CD taken out from the mechanism.
Make sure you have the security code BEFORE you take it out
Sep 02, 2009 | Pioneer Car Audio & Video
My ford mondeo 6X CD Sony is playing up all the time with original c.d's Can you help showing change cd check cd then suddenly works Do i need a c.d. cleaner?
The problem maybe that the drive gear that spins the disc is sticky. I had same problem, take cd unti out remove front facia then remove cradle that locks cd into dash. This give access to 4 screws, remove top lid on cd and temp connect facia and cd back in car load cd and watch to see if it spins up if not spin gently with finger. If it plays ok remove and gently oil between black drive disc and motor. Play cd again hopefully this will resolve problem.
Make sure laser is clean of any oil that may have spun off disc.
Best of luck it worked for me.
Apr 20, 2009 | Sony Audio Players & Recorders
Jammed cd
remove the negative side of the battery then remove the radio/cd player take the face plate off to get access to the CD
Jan 24, 2009 | 2005 Buick Rendezvous
Need to remove cd drive
if you want to remove cd drive means.....first you want to remove two wires from the cd drive.....you want to remove power cable and then data cable that is connecting to motherboard.........then you can easily remove the cd drive.....
Sep 20, 2008 | Sony Computers & Internet
CD player won't eject CD and does not recognize the CD
You will have to remove the player from your Sierra and disassemble it sufficiently to remove the stuck CD.
May 30, 2017 | Car Audio & Video
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
