I think the fuel pump on my beckett burner is clogged is there a way to clean it. Ive replaced the filters and get fuel to the burner but get no fuel up to the line feeding the nozzle
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 50 Answers
As you face the burner, mounted in the unit, the oil line feed in on the left side. There is a cap, held on by 4 7/16" bolts. Inder the cap, there is a screen. You would be best to get a screen kit, available from the same place you get your nozzle, as it will come with a new gasket.
Shut off the oil. Remove the four bolts, pull the old screen, clean the housing (I use rags and WD40) and re-asssemble. If is is really bad, you should remove the nozzle assembley and flush the oil line to the nozzle, as well.
THe oil filter, screen and nozzle should be replaced at least once a year.
Posted on Jul 20, 2010
Beckett burner starts and ignites but flame goes out slowly then get a lot of smoke why is this happening
It sounds like your filter is clogged. In the line from the oil tank to the burner there should be an in line filter. It is usually canister shaped and has a felt filter element inside. Shut valve off at the tank and loosen bolt on the top of the canister to remove bottom section of canister and access filter replace filter ( most hardware stores carry them) and reassemble canister. There is a small screw on top of the canister. Remove this to let air out when you open valve to let oil fill canister. When oil comes out shut off valve and reinstall screw. Reopen valve again and you should be ready for burner test. Setting a pan under the filter canister is a good idea to catch any oil from disassembling filter. Hope this Helps.
Bob
Oct 19, 2014 | Beckett B2502 Burner, Oil
I have an oil burner that is leaking. how can i determine if it is oil pump or something else?
Do you see oil or water? If oil then the pump seal is broken and you need oil Tec to change the pump.
Dec 31, 2013 | Beckett A2EA6520 Single Stage Clean Cut...
How do I wire a Beckett 12v diesel burner? I have a Beckett 12v burner igniter with a fire eye, a high limit switch, and a flow switch. This unit came with all the wires cut and missing a t stat and...
first do you have a fuel solenoid???i am a burner tech for thirty plus years.fuel solenoids are mounted on the fuel pump.flow switch.high limit switch and thermostat are connected in series to feed the fuel solenoid.
Aug 16, 2013 | Briggs & Stratton Pressure Washer...
Weill mclain oil burner beckett burner starts and stops
So you are saying it will run and shut off but NOT go into lockout? What is the boiler temp? Do you have a low water cutoff ?
Jan 27, 2018 | Heating & Cooling
Im trying to replace the oil pump on a beckett burner i took out the 2 bolts holding the pump to the burner but the pump wont budge. the line is disconnected and it is stuck in place.
1. Disconnect fuel lines, remove two fuel pump screws.
2. Remove motor and coupler by taking out 2 bolts. Remove motor wires, if needed, to place motor on the side as you are working on the pump
3. Clean pump mount from inside burner with a rag. Spray WD40 to loosen any accumulated rust or dirt and clean again.
4. Using a flat nail punch and a hammer gently knock the pump evenly on the mount to push it out from inside the burner. Repeat it, if needed.
Mar 13, 2011 | Heating & Cooling
Just bought a used karcher hds 500ci every now & again lots of smoke belches out burner is this a bad sign ? also cant seem to get the chemicals to pick up any tips
you burner assy needs to be cleaned , spark electrodes properly gapped and the fuel pump pressure set , the chemical pick up often gets clogged , and the chemical valve ( pump side becomes jammed ( a small ball bearing jams in the seat )
also clean out the diesel tank and clean or replace the fuel filter , if the smokes is white thats caused by water in the fuel , black smoke is too much fuel going to the burner assy or your ignition electrodes not igniting it
Nov 15, 2009 | Garden
3 year old Beckett AFG with Clean-Cut system. New inline filter new strainer, new nozzle, flame looks correct in pattern always. Flame does not sputter prior to shut-off. I did notice that when it shut off...
Called Beckett at 1-800-OIL-BURN and explained the problem. They told me that the solenoid on the oil pump (Clean Cut) was the cause. I purchased a new pump for $50 at the local plumbing supply and installed it. Problem solved.
Nov 20, 2008 | Heating & Cooling
Beckett home oil burner
problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Nov 01, 2008 | Water Heaters
Heating & Cooling Logo
465 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
