Question about Taylormade r7 Draw Fairway Woods
I have two Taylor drivers - one with a broken head and one with a broken shaft - can the shaft of one be used on the other to give one club that can be used?
  • Randy McLarry
    Randy McLarry Aug 14, 2010
    so you have a shaft that isnt broken with the club head still attached to it that is broken?
Are you willing to sell the package? I'm interested in picking up an r7 and I like doing that sort of work myself. It goes towards my credits. Give me a call if interested. Even if you still have the broken head I'd be interested in talking to you.
Christian
(253) 229-7248
Posted on Feb 04, 2011
Taylor model 754-27 soft serve machine getting water and soft serve in side tray on the the side of the machine. never happened before.
It's either:
A. The drive shaft boot seal - 032560 Boot Seal - You can buy them individually or as part of the tune up kit. They are normally replaced quarterly. Inspect this part when you take the drive shaft out for cleaning. It's very important that the drive shaft comes out every time you clean the machine and that you pack lubricant between the seal and the shaft.
B. The Shell Bearing - Taylor 031324 Replacement Rear Shell Bearing This is the metal sleeve that the drive shaft goes through in the back of the freezing cylinder. They wear out over time, they usually start to "mushroom" out grind down the boot seal.
031324-4 -5jpt2eusobswb402obrm5sjf-2-9.jpg Email me if you need a part or more help.
tex@softserveparts.com
Jun 07, 2017 | Taylor Ice Cream Makers
Tip
Cheap dent puller for small dings/dents
you can fabricate a dent puller to repair small dents on your body panel(s)
just weld/solder a phillips head screw to a phillips screwdriver. a slide can also be added to your puller by obtaining a 4"-5" long 1" i.d. steel pipe. slide pipe peice over driver shaft, then, obtain a bolt washer clearenced enought to slide onto driver shaft in front of the peice of pipe, weld/solder washer to driver shaft and you have a stopper to limit forward travel of the peice of pipe.
on Mar 27, 2009 | 1997 Dodge Ram 1500 Club Cab
What is the difference between N and NU in the setup of my r9 taylormade driver
From the link below:
Locking the head back in place with the torque wrench supplied free with the club, gives me four main settings to set up the trajectory:
*Towards L sets the club to give a maximum draw (presumably for those with a built slice or fade swing).
*Towards R sets the club for a controlled fade (for those who consistently over draw or pull tee shots)
*Neutral Upright (NU) delivers a slight draw (for those with a tendency toward a slight fade)
* Neutral (N) produces a slight fade (my preferred setting to counteract an occasional hook/pull)
Long term test TaylorMade R9 driver
Dec 02, 2014 | Taylormade R9 SuperTri Drivers
Engine run but don't turn
You're a bit vague in your problem description here, but I'm assuming you mean that when you give your machine gas that the cutting head will not turn. First I would check the cutter head to be sure that no trash has wound itself around the shaft preventing the head to turn...if that is not the problem turn the cutter head by hand and check to see that the bearing inside the cutter head has not seized, it should turn freely with no noise....if no joy check the cable which runs through the shaft from the engine to the cutter head it may be broken or frayed, also check to see that there are no problems with the clutch (broken springs, broken pads, or a broken key) that should do it ...hope this helps...;-D
Aug 09, 2010 | Ryobi Garden
The lower shaft on my ryobi stoped turning, how do i fix this problem.
You didn't quite give me enough info on which machine you have ... but if it is one that allows the lower half of the shaft to be removed for using other implements, disconnect the shaft and try to turn the inner splined shaft by hand and see if the head turns, if not you may have a broken shaft cable or a frozen bearing in the shaft head...this will necessitate removal of the head and replacement of either the shaft cable or the machine head...if all is working then check the shaft going to the clutch...hope this helps... ;-D
Jul 13, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Shaft snaped at club head
Find a local Golf Shop and have them repair it. You could do it your self but it's very tricky to get the correct angle with a bore through shaft. plus if you bought it with the original shaft, it has a specific swing weight you want to maintain. The Shop will know what flex, kick point, and length the shaft is as well.
Jun 22, 2010 | Callaway Big Bertha 460 Driver
Taylor made driver repair
You should take it to the closest golf shop like a PGA superstore or Edwin Watts. If you live somewhere that doesnt have those resources then I would go to the local golf course next to you and ask the club pro where he would have his clubs repaired locally. Who knows, they may also do it right there at the course. It will run you a little money to replace the broken shaft, but the work and new grip will be less than $20.00. Good Luck, You may ask the person you were riding with if they pulled a prank on you with the bag falling off, Ive seen it happen. lol.
May 12, 2010 | Taylormade r7 Draw Fairway Woods
More height off the tee required and ball flight to the left
If you are using an iron club...never place the tee high...the higher the tee with an iron, the more draw or fade you will get. Keep the tees closer to the ground and take your stance back a little too...
Mar 16, 2010 | Taylor Instruments Taylor Made R7 Quad 9.5...
Don't know where the weights go for a draw
With R9, they tried to maximize the fitting possibilities for each golfer. They engineered two independent and complementary adjustability systems into the head to cover a large range of ball-launch conditions. They use movable weight technology in combination with a variety of head angles and seamlessly integrate them into a beautiful shape"
The 430cc head features "flight control technology" (FCT). Simply, an adjustable head-and-shaft system (tighten the recessed titanium screw to an aluminum "sleeve" on the end of the shaft) gives you the ability to lock the head in eight different settings. The shaft (and "sleeve") go into the hosel off-axis by 1°, which allows you to tweak face angle (2° closed to 2°open), lie angle (1° upright to 1° flat) or loft (1°stronger or weaker than stated loft). Company brass says FCT produces up to 40 yards of directional flight variance. That's particularly good news for slicers or hookers. FCT combines with the firm's "movable weight" technology (three removable plugs that weigh 16 grams, 1 gram, and 1 gram) to generate as much as 75 yards of left-to-right shot bias, 3° difference in launch angle and 1,500 rpm of backspin. Fit yourself by positioning the face angle (FCT) and then move weights to dial in trajectory.
Oct 17, 2009 | Taylor Instruments Taylor Made R7 Quad 9.5...
Broken 4x4
once you have the passenger side/nearside drive shaft out use some thing long to slide in onto the head of the stuck drive shaft. use something soft like a old wooden broom handle then knock out using hammer. ford have used simple spring clips to keep there drive shafts in and thes are easily come by if deformed or squashed
Jun 02, 2009 | 1983 Ford Ranger
Taylormade r7 Draw Fairway Woods Logo
122 people viewed this question
Top Taylormade Sport & Outdoor - Others Experts
Are you a Taylormade Sport and Outdoor - Other Expert? Answer questions, earn points and help others
