if your sound is not working you can check that the plugs are in the computer correctly usally there are green and pink ends on computer speakers green indicating goes in the green slot and pink in the pink some people often gets confused and there are sometimes on new modles a blue slot that can look green in low light i would suggest checking they are plugged in correctly to the computer preferably in the back and not the front if the front option is avalible and check the appropriate drivers are installed on the computer to use the speakers
there must be a speaker problem in your phone.. kindly change the speaker of your phone. this will solve your problem. or else check your sound settings or in equalizer.. this will solve your problem..
Hi, problem can be solved. The problem can be from two places,
From the speaker and, also the cross over.
I might be from the speaker if the wire connected from the cross over inside the speaker has cut or has removed.,it can make the speaker (15),not to make any sound..
The cross over might also be the fault too. The cross over is located inside the speaker and it makes the 15 speaker makes sound.. 'There are capacitors on the crossover that control and makes the 15 speaker make sound.If the capacitor gets damaged it can make the sound stop. Also you will need to check the fuse inside the speaker, you will find the fuse on the cross over of the speaker.
just go into sound config on your computer, select your speakers & problem solved. happened to me when i changed my service pack with vista. for some reason speakers switched to bluetooth after install. just changed them back in your sound config, problem solved..
yes,just buy any audio video reciever(AVR),you can use this AVR by connecting all your audio and video system,it has a built in amplifier,by using an AVR system it will solve all your problem....
Be sure you have proper impedance with both sets connected. Some units have a selector switch in the back of the receiver to set the proper bias. ...accordianman
