Question about HP Computers & Internet
My HP Printer no longer works on my laptop. What
My HP Printer no longer works on my laptop. What do I do now? I've reinstalled the CD several times. Thank you.
  • 700 Answers
You did not provided any useful information, what operating system you use, what printer, what connection (usb, paralel, network) and what laptop.
general advice only can be provided then.
if windows of any flavour, disconnect the printer, uninstall all software pertaining to this printer. use ccleaner and clean your harddrive including registry.
check printer on another computer if it works. if printer works correctly, problem is with your laptop, not with printer.
follow this procedure, install software, connect printer, switch printer on, windows will automaticaly install drivers and printer software
if this do not work, you need to check if port used for printer work with other hardware, ie, usb stick, check cable between printer and relevant port.
Posted on Jul 20, 2010
Hp officejet j3640 not working on windows vista. I had the printer working and when disconnected when moved it doesn't work. I've tried uninstalling and reinstalling the driver several times....
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
Oct 29, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
I have the hp deskjet F4180 printer I have used for at least two years. My lap top is a Gateway Windows Vista. Recently the printer failed to print so I deleted the printer as it would not delete the...
HP software can often give you a headache. When you said you deleted the printer did you simply delete it from the control panel where all of your installed devices are listed? If that is the case you need to use HP's Uninstall program to completely remove all HP software for this device before attempting to reinstall the software. If the HP software is no longer listed under your "Start - Programs" menu you can use the Control Panel, go to "Programs - Uninstall a program" find the HP software and remove it. Once that is done you can use your friends CD if it is Vista compatible or download the driver at this link:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=al-64552-2&lc=en&dlc=en&cc=us&product=3177566&sw_lang=&os=2093
May 20, 2010 | HP Photosmart 4180 All-in-One Printer
Failure of F4180 DeskJet All-in-one to install
frist you need to uninstall the printer from the cd..insert the cd first then go to the cd do explore>>utill>>ccc>>uninstall l3..after that go to control pannel..add a remove program then delete all the programs related hp printers..restart the computer.then download the software from hp.com..reinstall it..it will work..best of luck!!
Sep 15, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Cd/dvd drive stoped working on Windows7(vaio vgn series)
un install the driver from device manager and restart your comp and then check your cd drive if it works fine if not let me know
May 22, 2009 | Acer Aspire 5610-4648 Notebook
Reinstalling printer without CD
Take a look at this webpage, you'll find drivers, software or even troubleshooting guides if needed.
http://h10025.www1.hp.com/ewfrf/wc/product?product=428800&lc=en&cc=us&dlc=en〈=en&cc=us
Jan 24, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Reinstall software each time the printer is reconnected
hmmm...maybe the way to do this is to use the remove hardware icon in control panel, instead of simply disconnecting the printer from the laptop.
also, go to www.hp.com and get the newest drivers, which are almost certainly more recent vintage than those on the cd.
Aug 20, 2008 | HP Photosmart C4280 Aio Printer
Document viewer msi
This problem is easy to solve. Just insert the installation CD that came with your HP printer into your computer when prompted to insert a CD. The file will be downloaded automatically.
Jan 17, 2008 | HP Pavilion dv4000 Notebook
CANON PIXMA MP170
my printer kepps on sayin check printer 5100 can some one hellllppppppp
Dec 10, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Computers & Internet Logo
159 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
