Question about Friedrich QuietMaster Electronic SS12J30D Air Conditioner
Our Quietmaster 's cooling works for a while and then doesn't.
Our Quietmaster blows the appropriate cold air when I turn it on, say at 10 in the eveneing. A few hours later, while the fam still operates, the cooling does not even when the temperature control is lowered well below room temp. Then a few hours later the cooling starts/cycles on again. Help!!
  • Friedrich Master
  • 3,740 Answers
Remove the front cover and make sure the temp sensing wire is in place on the front of the evaporator coils. If it has fallen and is touching the evaporator plumbing the unit can preform as you described.
Also check for signs of icing / ice build up on the evaporator coils after the uint has run for a couple of hours. Ice build up will also cause this symptom. IF you do find that the unit is icing up that can be caused by:
1. A very dirty evaporator
2.. A clogged Air filter
3. Contaminated by internal plumbing debris / clogged freon passages
4. A blower Fan motor running to slow.
5. Freon Pressure and return lines touching together usually either on the side of the unit or just behind the center chassis air wall enroute to the compressor.
6. A corroded electronic control board.
As you can see above there are several things that can cause the symptom your described. It cetainly sounds as if you either have an icing problem or a control board problem.
The next time the symptom occurs... place the unit of fan only for at least 30 minutes and then see if you can switch it to cool, and actually have it cool. If it does cool properly after switching to fan only for 30 minutes you most likely have an icing problem.
Thanks for using FixYa.
Kelly
Posted on Jul 20, 2010
How to replace coolant in air conditioner...
fan motor is bad stuck or relay or capictor if fan dont pull air thru condensor it does not turn to liquid and then wont evaporate or cool in evaporator
Aug 28, 2012 | Friedrich QuietMaster SM24L30...
My friedrich quietmaster does not turn on but touchpad turns on
If you are using A/C in cold weather. If there was water in base pan, the condenser fan blade might be frozen in ice. You would need to slide the chassis out 1/2 way out of sleeve to check rear condensor blade.
Aug 27, 2012 | Friedrich QuietMaster RS10J10 Air...
My Friedrich QuietMaster Series KS15L10 115V model will being to blow cold air and then after 5 to 10 minutes will trip the circuit breaker. We recently had a heat wave for about 2 weeks in which the unit...
Hello
Yes the northeast had temps that went past the limits of modern a/c.
Try cleaning the outside fins and coils.
Spray a product called simple green on the fins while unit is off.Leave on for 5 min.
Then rinse off with a hose.
This should keep your compressor running cooler.Also clean any filters in the inside unit.
Aug 03, 2011 | Friedrich QuietMaster KS15L10...
THE COMPRESSOR AND COOLING WORKS BUT THE FAN DOES NOT BLOW ANY AIR.
I would say the fan motor is not working you will need to take the casing off and look to see if the wires to the motor are off, or if the motor is frozen/stuck(will not freely rotate) Tim
May 29, 2011 | Friedrich QuietMaster RS10J10 Air...
I have a freidrich quietmaster wall air conditioner and the condenser works fine until you use the money saver then it starts to blow hot air
blowing hot air is the unit's way of further cooling its compressor, this should not last long and should cycle back and forth
May 03, 2011 | Heating & Cooling
The A/C is not blowing cool air
You can tell if freon is needed ,if you feel the coil,near the filter,all over,if it is not getting cold all over after 20 minutes of running,then it needs freon,make sure the coils are not dirty,and stopped up,before checking the evaporator (the one inside near wear the filter goes)
Jun 04, 2010 | Friedrich QuietMaster Electronic SS12J30D...
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
My AC is not cooling the air
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, it is not blowing cool air after you emptied the tank.
Turn the unit off and unplug it for 5 minutes.............
Then back in with the plug and turn it on max cool.
Give it 5 or 10 minutes to get cold, and we will see if this procedure has reset the system.
Then get back to me and let me know it's working!
How old is the unit?
Please remember to leave a rating before you go!
Thank you Huuum
Aug 04, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Friedrich QuietMaster Electronic SS12J30D Air Conditioner Logo
225 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
