Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Drive is not ready to be read ?Error Check/device/harddisk1/DR7 ?
When I plug and turn ON my hard drive, my computer is asking me suddenly to make sure there is a hard drive into the lacie -- and show me this notification (see the line up there) ?? Do you have any clue about this ? I tried to connect my drive to a MAC and the unit doesnt show up on the desk either !! Is the drive completely out ? Do I have lost all my data ??????
Thsk for feed back Jon
  • 700 Answers
If you external hdd do not show on other computers, usually it meant that power supply on these casings die... but in this particular case it is possible that power supplied by usb port is insufficient to support data transfer. connect recommended power supply (on the back of this particular model you have usb plug and power plug, power supply is/was sold separately) usually hdd inside is still fine and retain data.
if this did not solve your problem, i would suggest purchase little powered universal hdd craddle, they cost about $15 to $25, remove, hdd from casing and connect to the craddle. data should be then accessible directly from your usb port.
as long as hdd is turning, data is accessible and recoverable, even if disk was wiped off.
Posted on Jul 20, 2010
Device harddisk1 dr7
Turn off the power.
Make sure power and connector cables are hooked up securely.
Turn the power back on.
Jan 06, 2014 | Computers & Internet
Download harddisk1 dr7
if you are encountering problems with the disk not being recognised go to disk management and make sure it is their if it is not it is either not attached or is faulty.
when connecting a HDD you do not need a driver the OS will handle this for you.
Jan 04, 2014 | Computers & Internet
Device harddisk 1 dr7
there is no disk in the drive. please insert a disk into drive\device\harddisk1\dr7
Jun 14, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
My Rock Mobile Disk Drive is not working. Every time I connect it to my computer, the red light flashes and after a while of clicking, I get an error message screen that says "The specified I/O...
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 12, 2010 | SimpleTech SimpleDrive...
Windows cannot read my external hard drive anymore. It is tells me to unitialise it, and windows cannot even help because of an I/O device error.
Please check the External Hard-drive to some other computer
it it is working fine then check the services and turn on the plug and play
start - run - type services.msc
select the look for Plug and Play
Jan 03, 2010 | Seagate FreeAgent Pro 1TB External USB...
Hi, I get an error message when I try to connect and install a Maxtor 500 GB external hard drive to my computer. The message reads "the device cannot start (Code 10). Can you assist?
What is the error message you get?
What OS are you using?
Depends on your hard drive, some computer commonly ask for a driver when you plug something in it. might as well try reading the manual of your external hard drive, if it doesn't require a driver, then the problem "might" be in your operating system and/or in your computer.
Sep 26, 2008 | Computers & Internet
Lacie 250 gb gives error while accessing some folders
I took mine to a place to get it fixed and they said it was beyond repair and the only option is to recover the data and transfer it onto another disk
Jan 18, 2008 | LaCie (300728U) 250 GB Hard Drive
Format Hard Drive Error
If the unit detects any form of Hard Drive Error it asks you to format the drive. Connect the unit to your PC and run ScanDisk or DOS Chkdsk on the drive. Will help to rectify any issues with the FAT. Windows XP & 2000 Running Check Disk Utility (ChkDsk) ? HARD DRIVE mode only If you still have problems with the file system on your AV 500 you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the AV 500. ? Quit all running applications. ? Properly connect the AV 500 to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f . Use e: or f: or whatever drive letter is representing your AV 500. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When finished, exit the DOS Window and properly disconnect the AV 500 from your computer. Now try using the device. DO NOT try to defrag the drive. Let us know how you get on.
Jul 26, 2007 | Archos AV 500 Digital Media Player
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
828 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
