Not looking exact colours on lcd monitor(like pink colour). model is hcl a170E1-08.
    Brigadier General:
  • 10,406 Answers
Connect the monitor to an alternate (desktop or laptop) computer, to see if the monitor itself is the problem.
Connect a different monitor to your computer, to see if your computer is sending the "wrong" video-output.
Try a different "data" cable between your monitor and your computer.
Posted on Jul 20, 2010
V LCD Monitor D19W12 how do I adjust color - it is all PINK?
Make sure that the "data" cable between the computer and the monitor is tightly-connected at both ends.
Try a different "data" cable.
Try connecting the monitor to a different computer (laptop or desktop).
Note that 'WHITE' is generated by mixing all 3 "primary" colours.
If the video-card on your computer is not generating all 3 colours, then 'PINK' could be the result from mixing the remaining 2 "primary" colours.
Aug 18, 2011 | ViewSonic VP211b 21.3" LCD Monitor
Contrast is pink. Cannot get it white.
PINK is a mixture of just two of the three "primary" colours.
WHITE is a mixture of all three "primary" colours.
So, your monitor is NOT producing one of those primary colours. or is not producing the right "mix" to get from RED to DUSTY ROSE to PALE ROSE to WHITE colours.
Jun 27, 2011 | Envision Computers & Internet
The monitor color is pink...i want it to change to normal color...
Colors on the monitor are produced by mixing the three "primary" colours.
If the monitor is not producing one of those three colours, you can get "pink" instead of "white".
Fix the monitor, or replace the monitor, or replace the video-card (if using a different monitor also produces "pink").
Jun 21, 2011 | Computers & Internet
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
My monitor resolution colour is changed to pink.
Check the data-cable between the computer and the monitor, and try a different cable.
Or, try connecting the monitor to a different computer, to see if the video-card in your computer is not working correctly.
If necessary, replace the video-card.
Colours on your monitor are produced by "mixing" the 3 "primary" colours: red/green/blue in various proportions.
Or, if part of the monitor that produces one of those 3 primary colours has stopped working, then the resulting "mix" will have too much RED/PINK. Fix/replace the monitor.
May 29, 2010 | SAMTRON 55V 15" CRT Monitor
My lcd monitor colours are
Hi There!
Sounds like this may be the cable between the monitor and computer. It may also be dry joints on the logik board. The board where the signal cable plugs into. This socket may have loose connections or dry solder points on the board. Hope this will help you. Please be careful when opening the screen as it can damage easily. Try refrain from handling the screen on the front. Best Wishes and Good Luck, JUS004
Sep 14, 2009 | Acer Computers & Internet
Monitor display and colour settings are not correct
Did you install the monitor driver? It sounds like you did not. 75Hz refresh is high, try reducing it to 60Hz at least long enough to get your settings fixed.
May 27, 2009 | HP D1560 Deskjet Printer InkJet
Monitor no display
hi, check out the connector pins if any is damaged or bent, if not try it on a different system just to confirm that its not the display card problem, let me know??
Oct 20, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
106 people viewed this question
Alun Cox
David Payne
David Payne
