Scanjet 5400c won't scan in Vista Home Premium
    Sergeant:
  • 221 Answers
Unfortunately, your scanner is not compatible with Windows Vista and there are no drivers available to make it compatible. I found the following message on the HP website when I searched for Vista drivers for your product:
We are sorry to inform you that there will be no Windows Vista support available for your HP product. Therefore your product will not work with Windows Vista. If you are using the Windows Vista operating system on your computer, please consider upgrading to a newer HP product that is supported on Windows Vista. HP has numerous products on the market that support Windows Vista. If you are in the US, see http://www.hp.com/united-states/tradein/home_flash.html . If you are outside the US, click the How to buy link at the top of the page.
Posted on Apr 22, 2008
I'm wondering, why HP doesn't support there products?! Scanjet 5400c is in good condition and I don't want to spend more money, because somebody else doesn't wont to do his job!
Hi droussanov !
Hp doesn' t support your unit anymore since Windows XP and it's a shame . Here are 3 workaround solutions :
solution one:
You can get your unit working in WIA mode if you can follow this :
make sure your XP ( yes XP ) driver is correctly installed .
Download FreeKapture from
http://download.cnet.com/FreeKapture/3000-2094_4-10673689.html
Launch Freekapture , clic on Scan , select WIA-Hewlett-Packard . Your scanner will run . If you choose HP PrecionScan Pro , program will hang .
Note : no slides or negatives scans possible in WIA mode but the rest works .
solution two :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
solution three :
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.
Back up your data first.
Have a nice day ,
Best regards,
Fanaudi .
Feb 10, 2011 | HP Scanjet 5400c Flatbed Scanner
My HP Scanjet 5400C Scanner has decided to stop working. The 12 volt mains transformer feels cold and no light comes on the scanner. It appears that the transformer is US. Where can I buy a replacement
You can probably get this from HP. See http://h20141.www2.hp.com/Hpparts/Search_Multi_Product.aspx?mscssid=42F39AE6AD6B4EFBBC921EC42BADCDE3&SearchCriteria=Scanjet~5400C and select your model. There are 4 versions of the ScanJet 5400C listed. Then select power module in the drop down menu and click on the arrow; power cords are listed separately. Alternatively, click on the arrow for show all parts. The listings are clearly labeled for the country electrical system with which a given part is compatible.
I hope this helps.
Jan 08, 2011 | HP Scanjet 5400c Flatbed Scanner
Driver for windows vista home premium sp1
HP doesn't have a Vista driver for Scanjet 3400c. I'm afraid your scanjet isn't compatible with Vista.
May 06, 2009 | HP Scanjet 3400c Flatbed Scanner
Hp 5400c scans blue images
sounds like a faulty scanning head to me......
when images are scanned they are normally imaged in 3 colours red blue and green these are then combined to give a full colour scan. sounds like you are only getting the blue pass.
not alot that can be done here, if it is in warranty (check with manufacturer for duration of warranty as sometimes this can be more than a year) they should repair or replace this for you
Apr 23, 2009 | HP Scanjet 5400c Flatbed Scanner
When I scan back screen comes up blue and words and numbers are
http://fixunix.com/hewlett-packard/101142-scanjet-5400c-dead.html
following this link i've found resetting instructions for this scanner:
1.. Disconnect the USB cable and the power cable from the
scanner. Make sure the power cable is still connected to the
power source.
2.. Press the Scan and Email buttons at the same time, while
plugging the power cable back into the scanner. The scanner will
enter a Demo Mode.
3.. Press the Cancel button on the scanner to start the test.
4.. To end the test, disconnect and reconnect the power cable
without holding the buttons down.
I've had exactly the same problem with my scanjet 5400c (blue distorted images) but after resetting the scanner (see instuctions posted above) the problem was fixed
Dec 18, 2008 | HP Scanjet 5400c Flatbed Scanner
4200 hp scanjet not compatible with vista
I used the HP latest driver download named sj655en.exe from their website and after 29months of not working, it DID and DOES work now!
The HP Precision Scan LT interface has a little problem of "save as" naming your file since it does not show the file name but you can just add the file name to the folder name and then it'll save your scan.
All of my apps work fine using the import function to the HP Precision Scan LT application.
Since I know HP did NOT update their driver, I'm guessing it's Microsoft having changed something with Vista Home Premium.
Good luck with your re-try of getting the old HP4200C Scanjet working again on your Vista operting system.
Aug 13, 2008 | HP Scanjet 4200c Flatbed Scanner
Precision Pro 3.1
You may want to try this web page that tells you how to get the HP 5300C
working in Vista. It works fine on HP 5400C as well.
'Tutorials - How to get your HP Scanjet 5300c working in Windows Vista'
(http://www.pixel2life.com/publish/tu...windows_vista/)
Jul 29, 2008 | HP Scanjet 5400c Flatbed Scanner
Driver HP Scanjet 3800
U CAN EASILY FIND THE DRIVERS AT FOLLOWING SITES-
www.driversplanet.com
www.download.com
www.drivers.com
etc.
& please rate me nice too.
Jun 23, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
David Payne
David Payne
