Amana error code 6p
I am trying to find out what the error code 6p is on my Amana washer model # LW4603L
  • Sureshsi Feb 28, 2009
    I have the same error code "6P" - washer won't run after pressing start and the display show this error code after stop switch. AMANA Model Number LW9203W2. Any help is appreciated.
2 Suggested Answers
SOURCE: what does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Posted on Sep 01, 2010
Amana washer error code
This is an open door error. check the latch and switch on the machine.
Feb 05, 2014 | Washing Machines
My Amana LW9203W2 washer will not fill. When a cycle is started, it goes straight to agitating. The error code it provides is 6P. I'm assuming this is the pressure switch, but I don't know if...
Try this first!
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Aug 20, 2011 | Amana Washing Machines
What does error code 6P mean on an Amana washer model LW9203W2B
Dec 29, 2009 | Amana Washing Machines
Fault code on an Amana Washer
The door is open. Be sure that the door is completely closed.
Jan 21, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Washing Machines Logo
206 people viewed this question
Top Washing Machines Experts
