Question about Business Objects Crystal Reports XI Developer Solution Suite
Developer key - Business Objects Crystal Reports XI Developer Solution Suite
    Guru:
  • 195 Answers
Visit www.businessobjects.com/.../crystal/reports/developer/
Posted on Jul 20, 2010
How to install developer in a new Ricoh Aficio MP1900. I have a new MP1900, there is no istructions to install developer in the machine, I know that I need enter in service mode to set developer: someone...
I suppose you have the developer in the developer unit, YES????
If so you just need to do developer initialization.
Press yellow key.
press on the key pad 107.
Old red key at least 3 sec.(if you did everything well you are in SP MODE)
Press 1 (to copy sp)
Search 2 drum (one time on the left key)
Press ok
Search SP 214 Developer initialization
Press execut
Hope you understood. Good luke.
Feb 17, 2011 | Ricoh Office Equipment & Supplies
A) Developer signal is always showing after replacing developer.How can it be solved? Man signal is always showing. B) New toner has been replaced but also it is printing light.
A) To reset developer signal press: # key __ interrupt key __ C key __ interrupt key __ 42 __ ready __ 1 __ ready . and you may have to check program 41 for developer counter cycle
B) check the developer
Dec 16, 2010 | Sharp AR-5316 Advanced Digital Imager...
DEVELOPER COUNTER CLEAR IN SHARP 5127 \r\n NOT WORK
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
Clear key, Interrupt key , "0" key , Interrupt key , 42, Start key , 1 , Start key
Developing counter clear.
Nov 30, 2010 | Sharp Office Equipment & Supplies
HOW CAN I REMOVE Key Maintenance MARK BY USING THE PROGRAM and How quantaty of devolper which requier
What is the "key maint mark"????
Do you mean its asking for a user code or is it asking for maintenance.??
The Developer comes in a bottle...all of the developer is replaced and then you need to access the Simulation modes to be able to run the developer set-up or the machine will not know you have replaced the developer.
Jun 23, 2010 | Panasonic FP-7735 Black and White Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
How do you enter simulation mode and the code when you replace developer on lanier 7313.
Press C00C or C interupt key 0 interupt key and 41 for developer counter display 42 for developer counter clear 46 for exposure level adjustment 72 for maintenance preset counter setting 25 for automatic developer adjustment. 40 for developer preset counter display.
Nov 10, 2009 | Lanier Office Equipment & Supplies
I replaced the drum in Copystar 1820. What code
1-4-1 Maintenance mode
1) Executing a maintenance item
Press the System Menu/ Counter Key
Select Service Setting using the up/down cursor key
While pressing the start key and the # key press the enter key
Select maintenance mode using up or down cursor keys
Press enter key
Enter the maintenance item
number U-130 using the up/down keys.
The selected maintenance item is run.
Press the back key.
Press the enter key.
Start
End
Run another maintenance
item?
Turn power switch off and back on
U130 Initial setting for the developer
Description
Executes toner install operation.
Purpose
To operate when replacing the process unit.
Method
1. Press the enter key. A selection item appears.
2. Select On using the up/down cursor keys.
3. Press the enter key.
4. Turning the power switch off and back on.
ADDING TONER is displayed and installation of toner starts.
5. After approximately 15 minutes, the installation is completed and the machine becomes ready
.U157 Checking/clearing the developing drive time
Description
Displays the developing drive time for checking or changing a figure.
Purpose
To enter the developing drive time again after carrying out initialization with U020 and to clear the developing
drive time when replacing process unit.
Method
1. Press the enter key. The developing drive time is displayed in minutes.
2. Change the setting using the left/right cursor keys or numeric keys.
Setting range: 0 to 99999
To clear the developing drive time, set the value to 0.
3. Press the enter key. The value is set.
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
I hope this isn't too confusing for you, but this is what has to be done when replacing the Drum Unit (Process Unit Assembly)
Sep 14, 2009 | Kyocera Copystar CS-1820 Black and White...
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
Turn off developer led
HII.best way is that u have to replace developer with new one .new developer will reset it automatically.for to reset in this condition
press clear key ,exposure mode key,clear key,exposure mode key,
copier will go dead .press 24 then start 06 start
developer counter will bi reset
do not forget to rate the solution
MIAN AKHLAQ
Mar 17, 2009 | Sharp Office Equipment & Supplies
Computers & Internet Logo
217 people viewed this question
Top Business Objects Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Business Objects Computer and Internet Expert? Answer questions, earn points and help others
