Question about LG L1730S 17" LCD Monitor
I have a flatron 1730S monitor. Last night I turned it off as the display was disturbing my sleep. Now it is stuck in powersave mode. I unfortunately don't have another montior to check the connection with but given I did not touch the cables at all between turning it off and back on and have since checked both the power and data cables. I have no idea what could be causing this. Can anyone help me? None of the menu buttons work either. Nor does rebooting the machine.
  • 6,826 Answers
I couldn't find this monitor listed on the lg.com website.
Is that the right model #?
How old is it?
Posted on Jul 20, 2010
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
When I start my PC or if the monitor is on sleep mode, on starting the screen goes on & off for about 20 to 3o times before it settles.
go to start-controlpanel-power options-change powersaver to balanced,under change settings u can adjust timings for turn off display and sleep mode.
May 21, 2011 | Computers & Internet
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
I have a LG Flatron 22", LCD monitor, model is W22345. dilemma: after sleeping the computer for the night, as I have been doing for the past 8 months that the computer and monitor has been in my owne
Check the video cable,replace them, and if didnt work, try to reset the config stored on the settings of the monitor (usually by menu).
Some electronic problems could do the same simptom. check the manual for hints.
Good luck
May 23, 2009 | LG 22" FLATRON LCD Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
Stuck in power saver mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Nov 03, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Jun 03, 2006 | LG 1720B 17" LCD Monitor
LG L1730S 17" LCD Monitor Logo
193 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
