Question about Denon AVR-1907 Receiver
I've Denon AVR 1907, Its not giving video output, I've connected DVD, DTH reciever and multimedia player thru it (using RGB cables). I can listen to sound (using digital cable) but can't see video, i've tried by replacing all the RGB cables but no use. Please suggest what could be the problem.
5 Suggested Answers
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
  • 119 Answers
SOURCE: Describe your Denon AVR-3805 7.1 Channels RecI
There is a button on the front of the unit under Input its a mode button press this button to select auto that should give you sound
Posted on Aug 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: Hi. I've got a Denon AVR-1907
Have you considered your source may be the problem if the receiver isn't?
You say setup is correct. If so it would work, no?
Posted on Aug 05, 2010
bshldn
  • 736 Answers
SOURCE: I have a Denon AVR
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
Posted on May 25, 2011
Denon AVR 1609 7.1 Channel Receiver turns on but i get no sound thru the optical to the tv. what could be wrong?
If you have your video equiptment hooked to your reciever input, then, out to TV, This isn't the best way to go. Of course it depends on what you have for input and output on your TV but, the ideal way to hook your system would be to hook all video equiptment to TV, ie:, cable/sat box, DVD player, etc., to TV via, HDMI, Composite, RCA, etc., then run your digital optical out from TV to reciever. You would use the TV's menu to choose what you watch and would only have one input(audio) to reciever. Some recievers are set up to transfer video, but, it uses more cables, creates more connections, and more room for error.
Jun 13, 2011 | Denon Audio Players & Recorders
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
May 25, 2011 | Denon AVR-1707 Receiver
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
Video does not work All this while, I had never used the video components of my AVR 1705. Recently, i wanted to connect the component out of the cable set top box and dvd player to the avr and the output...
Hi
The settings on many DVD players and TVs may need to be set to indicate the type of input/output being used(RGB vs YUV/YPbPr, and if set wrong the image may not be properly displayed. Try Look for such settings in your TV and/or Amp!
Good luck
Bruce
Dec 07, 2009 | Denon AVR-1705 Receiver
Noise coming out of speakers connected to Denon AVR 1908
Check for nearby wireless devices and move them away. -If the audio output from the source device (i.e. DVD, CD player) is digital (i.e. PCM, DTS or Dolby Digital) you're on your own. I'd be willing to bet the output is analog (red and white RCA), because the "beeps" and "exploding sounds" you describe seem like it could be caused by interference. Try replacing the cables. Otherwise the issue is probably with your receiver.
Aug 11, 2009 | Denon AVR-1908
I am having troubling hooking up my PS3 to my denon AVR-1907 receiver. I am using the PS3 component inputs and hooking them up to the "VCR" input.
Connect your component cable to the PS3 OUTPUT (there is no input) and connect that to the component IN on your receiver.
Jun 14, 2009 | Denon AVR-1907 Receiver
DVD Connection
hit video one or whatevr its on whats your out put ? coumount cable also
Jan 25, 2008 | Denon AVR-1907 Receiver
Denon AVR-1907 Receiver Logo
151 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
