Question about APC Smart-UPS SURT6000XLI (APC1363) UPS System
My apc SharePoint SURT6000XLI - 230V Smart UPS RT 6000VA wont turn on or charge the batteries
  • dustin_a_bou Jul 20, 2010
    my apc SharePoint SURT6000XLI - 230V Smart UPS RT 6000VA doesnt turn on or charge the batteries. i want to talk to a certified apc technicion
  • 942 Answers
Try to remove the power cable from the wall outlet. Then check if you have a circuit breaker reset button. Press and hold it for 2 secs. Then press and hold the power button for 4 secs. Reinsert the power cable and turn on the machine. Check if it will beep continuously. If it did not charge and still wont turn on and with long and never-ending beep, it might be a battery problem or the main circuit of your machine. Contact APC for possible battery replacement.
Posted on Jul 20, 2010
  • 6,826 Answers
Check circuit breaker button if so equipped.
Check that the wall outlet has power with a lamp.
If the above doesn't solve the problem, it's likeley the batteries are bad or the circuitry inside the unit is bad.
Indicates a need to replace unit with a new one.
APC Smart-UPS RT 10000VA 230V battery charging voltage high
voltage is ac,,,,better get a new one before u fry your self
Nov 09, 2013 | Computers & Internet
Input Voltage
Setting must be from the APC PowerChute software
May 11, 2013 | APC Smart-UPS (SU5000RMT5U) (SU5000RMT5U...
Our APC Smart-UPS RT 5000VA 230V : SURT5000XLI is constantly beeping every 5 minutes, what might be the issue, we did not replace the batteries for past 6 Years, is there any issue with Batteries? if yes...
The chances are great that the batteries are bad.Sealed lead acid batteries generally have a life span up to about 7 years depending on original shelf life and usage.
Mar 13, 2013 | Computers & Internet
UPS SURTD5000XLIQ is being powered but indicating red Led fault , What may be the cause ?
it is cause by UPS internal fault, possibilities like faulty charging circuit, inverter, etc.. you can call APC and check if its still have warranty, APC will replace it right away :D
Dec 27, 2012 | APC Smart-UPS RT 5000VA (SURTD5000XLI) UPS...
No logic power when input breaker is closed
double check your batteries, SURT UPS wont turn on if the battery is totally drain
Dec 05, 2012 | APC Smart-UPS RT 5000VA UPS System
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
HOW CONNECT ON LINE UPS WITH AC
Hi, Input power should has hard wire but on output has no wires ( is just receptacles). See below details :
Input connection :
230V, 50-60 HZ (Hard wire: 3 wires) ? connect to power source
Output connection :
(8) IEC 320 C13
(2) IEC 320 C19
? Connect this port to your loads
Dec 07, 2010 | APC Smart-UPS® RT 5000VA UPS System
How Icalculate the back periode of ups?
look at back of ups, it will have rating plate
eg
230V 3000VA
pf= .7 2100WATTS
72V DC
in this case we have a 230Volt 3kVA ups at .7power factor giving a total of 2100watts of power.
batt is 72Volts DC
ups on bench, batt at full charge with lamp load, usually I connect 75% load eg 1575 Watts, then fail supply and time batts to batt alarm point.
recharge and test again.
can be done with any size ups, other way is to put in data into makers web site and they should give approx batt times for different loads.
Sep 07, 2009 | APC Smart-UPS RT SURT6000RMXLI (APC9672)...
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
APC Smart-UPS SURT6000XLI (APC1363) UPS System Logo
208 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
