Question about Integra DTR-7.1 Receiver
Power tripped out cannot access video sores when trying toaccess video 1 i am getting dvd sourse
  • 3 Answers
Hi, I am Ashish from India. I would like to know that did you solved your receiver's problem or not? If not than would you like to sale it as it? If yes than can you send me few original images of your Receiver/Amplifier?
Thanks Ashish
Posted on Aug 08, 2010
  • 12,061 Answers
Http://www.retrevo.com/support/Integra-DTR-7.2-Receivers-manual/id/550ag003/t/2/
filedepot.onkyousa.com/Files/own_manuals/ADM-2.1.pdf
Below,is the support website for your convince. www.integrahometheater.com/model.cfm?m=DTR-7.1...
I have seen this type of things a few times before in my shop, What has unfortunately happened is that when the power went Off/came back On, it has "Spiked" the Computer Controlling circuitry internally.
Sometimes, if possible, one may be able to "Reset' the unit. But, usually, serious damage has been done. I have given you a link to a manual so you can check.
Posted on Jul 20, 2010
Elonex xv-s telvision no remote control cant find sourse to connect playstion without it.sky box is picked up automatically when switched on. it on scart connection
37" Elonex Widescreen HD LCD Television (Black) - Aria ...
www.aria.co.uk/.../Televisions/.../37%22+ELX+Widescreen+HD+LCD+T...
Buy 37" Elonex Widescreen HD LCD Television (Black) - HDMI, 1366x768, 1200:1, 8ms Product Name: 37" LCD TV Model No: LT37V1 Main. ... 49~61KHz; FrontControls: Power, Source, Menu, Channel Up, Channel Down, Volume Up, ... Have you tried it with a HDMI connection as I can't seem to get mine to work with my ...Missing: playstion
[PDF]Operator's Manual - SunBriteTV
https://www.sunbritetv.com/media/pdf/...R/3230HD-Op-Manual.pdf
6) Do not install near any heat sources such as radiators, heat registers, stoves, ....Water-Resistant. Wireless Remote. Control. Model 3230HD. TV Installation .... If youcannot achieve that ... to both your DVD player and Composite's S-Video connector ....Connect an HDMI cable to the HDMI output of your Playstation 3.Missing: elonex
Jan 12, 2016 | Televison & Video
DVD is stuck in player. It will not eject.
Make sure it is powered on. Press power-on button then try to eject. If not, then press the power-on button and try to eject. If neither works, return to the sore or website where you bought it and ask for replacement.
Dec 26, 2017 | Insignia NS-24LD120A13 24in 1080p LCD HDTV...
Tryin to hook up jensen vn9312 to a gmc 2001 yukon. the sourse light lights up but nothing responds
I am having the same problem. I sent it for repair and they said it works fine. online everyone said it might be a parking brake or grounding issue. If i find out ill post it
Sep 18, 2011 | Jensen's VM9312 Car DVD Player
I have two jl audio 12 w6v2 running with a jl audio 1000/1 and at high volume they make a poping noise does any one know y
Could be a power serge in your remote wire try different power sourse could be alot of things id try this 1 1st
May 10, 2010 | Jl Audio 12W7 Car Subwoofer
Blue screen, dvds wont play. cant change the sourse.
check you wire connections if not then you can get a originald remote from partstore.com good luck.
Jul 12, 2009 | Televison & Video
Cant get any power to the deck?
if 12v sourse and ground are connected check under hood for fuse block make sure all fuses are good also check cab of car and verify all fuses are good and check wiresconnected to player for fuse as well as the unit itself if still no power verifyall connections are tight. If this does not work your unit is bad you could try opening it and looking for visual damage i.e. button for power has a broken wire
Apr 13, 2009 | Car Audio & Video
My computer have Asrock K7S41GX,amd athlon 1.16GH,nvidia geforce fx5200 128 agp 1,5v video card,and 2 hard disk and one dvd-rw i keep getting problems with "him",its keep getting close up,like a shut down...
You may want to set all your drives (hard drives and DVD-R) to cable select setting. Sometimes this helps because it will enable Windows to designate drive sequence for you. Just a thought.
Dec 28, 2008 | Asrock K7S41GX Motherboard
Bootup,hardwere,,or some problem....
Sudden shut downs are often heat related. Modern motherboards have a sensor under the CPU that cuts off the power when the temperature gets above a certain point (sometimes this point can be set in the BIOS). Usually the CPU fan will spin up very fast trying to cool off the processor just before it shuts down. Often you can feel the heatsink being very hot as well.
I suggest you check your vent holes for clogging (hair, dust, etc.) to make sure you are getting good airflow. Next, peek into the CPU fan to see if there is dust accumulated underneath blocking the heatsink from expelling heat (the dust layer acts like a blanket and keeps the heat in). Finally, if you are technically inclined you can try removing the heatsink/CPU fan and reapply thermal paste to the processor.
Dec 27, 2008 | Asrock K7S41GX Motherboard
Yamaha RX-V420 Will Not Power up
Hi Daniel if your set does not have a fan that trips on when the volume gets louder surely the audio output will damage. every working component generates heat and when the heat sore up to an uncontrolable level it cause damage.have a tech look on your set to repair it.good luck.
Apr 26, 2007 | Yamaha RX-V420 Receiver
Disc access after finalizing
Get the software IsoBuster. It will analyze the disc and extract the images that are still there.
Jan 01, 2007 | Panasonic Palmcorder VDR-M50 DVD Camcorder
Integra DTR-7.1 Receiver Logo
173 people viewed this question
Top Integra Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
