Question about Asko D1876 Dishwasher
I have an Asko D1322, about 2 years old. All is good with the washing but the dishes when it finishes are still very wet. The fan appears to be running and I'm getting a small flow of air out the vent in the bottom left of the door. Does the fan need any maintenance? I was wondering if this might improve air flow and get rid of the condensation quicker.
abhishek33
  • 1239 Answers
SOURCE: asko dishwasher model 1585
hi Servicing the Door Switch
On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
©2006 Publications International, Ltd.
For repairs to the timer, door latch, or switches, remove the control panel. To take it
off, remove a series of retaining screws and the control knobs, and lift off the panel.
Posted on Sep 14, 2008
  • 14 Answers
SOURCE: Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Posted on Jun 18, 2009
SOURCE: Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Posted on Mar 17, 2010
  • 83 Answers
SOURCE: My Asko D1976 dishwasher is
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Posted on Sep 19, 2010
HansPP
  • 2510 Answers
SOURCE: Our Asko dishwasher no longer cleans the top shelf
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Check also that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Posted on Feb 04, 2011
Testimonial: "Super service, thank you so much."
Ld 14aw3
Most dishes in any dishwasher are still wet when cycle is finished. The heat built up in the dishes during the washing cycle is what causes the water to evaporate when the machine stops.
If you want to accelerate the evaporation, simply open the door very slightly so that as the hot air escapes it causes the dishes to dry quicker.
Aug 04, 2014 | LG Dishwashers
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
The heating cycle has changed and there is now a shorter cooler activity
the fan is probably busted. may just need to replace the fan. but if its washing the dishes fine and drying them , then you probably shouldnt worry too much about it.
Nov 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Asko D1996. 2 wet spots on floor in front of unit, (~1/2 cup). It continued to run, but the inside bottom of the machine was dirty, as though it slowly drained its wash water. Dishes mostly clean..
If you can open the panel and allow the panel to dried then tested to confirm before the panel is removed.
Use a hair dryer or a good air jet to remove all moisture from the panel and see if this works.
Oct 27, 2011 | Asko D1776 Stainless Steel Built-in...
Dishes are no longer coming out as clean as they used to, especially bowls or utinsiles with dried on food. The machine appears to function ok, but is about 8 years old. The machine just seems tired. Am I...
Hello, Those are common issues with dishwasher's as they age, and very good questions. The Asko dishwasher however is a very good hi-end machine and typically good for much more than 8yrs. That being said, 8yrs. is subjective isn't it ? I mean some unit's run a cycle 2-3 times daily while other's may only operate 1-2 a week, so "8yrs." is not always a level playing field. I digress, the first thing I would check is that the machine is filling with water during all parts of the cycle ( run a test and check specifically towards the rinse stage ) sometime the fill valve will work for the initial fill but fail to open again afterward. Also insure the unit is dispensing the wetting agent/jet dry and feel for air flow at the bottom left hand side of the door panel to confirm the fan is, 1) working, and, 2) the exhaust duct/housing aren't clogged, and therefore not permitting a proper rinse/dry cycle. The fan may actually be operating but yet the component which allows the condensation to exit the unit via the housing/exhaust chamber may be faulty, that would be the "wax motor", which can be burnt out or simply obstructed from working by water scale, food debris etc. All of which are easy to repair if you are capable of dis-assembling the door panel, or you may opt to call in an authorized Asko service provider. I certainly wouldn't seriously consider replacing such a quality machine (in my humble opinion)...at least not yet :) In the end worn wash impeller's are a factor, but so are so many other thing's. The main wash motor & pump are not where I would START, instead I would perhap's arrive there after ruling out many other factor's. Let me know if I can assist you further and thank's for visiting "fixya". Please take a moment and rate the service provided for you by me here. Good luck. macmarkus :)
Apr 10, 2010 | Asko D1706 Built-in Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Asko Excellence Dishwasher Model # 1504
I have a manual for 1504 and it says F2 blinking means high water level in machine
Apr 15, 2008 | Asko W6021 Front Load Washer
Error codes
Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
May 26, 2007 | EuroTech 24 in. EDW194E Built-in...
Open Questions:
See all Asko D1876 Dishwasher Questions
Asko D1876 Dishwasher Logo
127 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Jose Pino
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
