Question about GPS
My tomtom doesn't hold a charge and it has touble finding a location.
    President:
  • 1,197 Answers
First thing to check is are they actually being charged ALL the time you have them on charge. A couple of Ones which I've repaired myself had problems with the soldered joints for the connector on the printed circuit board. When the plug was wiggled about it made an intermittent connection and wasn't charging all the time.
Connect your charger and try wiggling the plug gently.
also your contacts may require cleaning this can be ddone by spraying "Switch Cleaning Lubricant" onto the contacts on the base of the unit.
Definitely make sure its actually charging, usually this can be done through the menus to see satellites and the battery life indicator. It will show if its charging or not...Electronic cleaner or even rubbing alcohol on a q-tip can work on the terminals. Making sure the charger is unplugged and the device battery is drained before cleaning should be a priority...
How old is the device. Despite what Garmin and Tomtom tell you Lithium Ion while being a good technology has its limitations, and the main limitation is its overall life span in combination with how fast it goes from what seems to be a good battery to something that barely holds a charge for a few minutes...
Its a standard lithium ion battery inside. It can be replaced relatively inexpensively. However getting too it can be tricky and I'd suggest reading up on battery replacement before attempting. Also for future reference keeping a lithium ion battery fully charged all the time will keep it lasting longer unlike older batteries that would develop a "memory" and benefit from being drained completely from time to time... the trouble finding location could possibly be attributed to the amount of power it gets from the batteries.
Posted on Jul 20, 2010
WHY isn't MY TOMTOM CHARGING? It's BEEN PLUGged IN FOR 45 MINS.
Usually an old (or older) battery will no longer hold a charge ... or will only hold a small charge (that will let you run the GPS for only a few minutes).
Often, when the TomTom device is always connected to the charger (in a vehicle), where it charges every time the car is turned on, whether the TomTom is being used or not, the battery gets charged (partially or fully) often enough to use up the "maximum number of charge" cycles for the battery. Hence, it will no longer charge properly or hold a strong charge.
Like for all lithium batteries, it's better if your device is not always connected and being charged (whether you are or are not using it). The battery will last longer and it will still be able to hold a stronger charge.
Feb 24, 2016 | Tomtom GPS
My son put a password on this tomtomxlone. he is7 and doesn't remember what numbers
PRESS AND HOLD DOWN THE POWER BUTTON FOR 15 SECONDS AND RELEASE THIS WILL FACTORY RESET YOUR TOM TOM FOR FREE.. TOMTOM CHARGE £55
Jun 01, 2011 | Tomtom One XL GPS Receiver
Poor gps reception on tomtom xl 340
The Tomtom devices need to locate GPS satellites in the sky in order to work. Unlike TV satellites, these do not have fixed positions but move relatively to the ground. The Tomtom can locate them by scanning the hemisphere, but this takes up to ten minutes after you switch on the device.
To speed up the process, the Tomtom receivers can use a helper file stored on the device. It holds precomputed positional data for the GPS satellites that makes finding them a matter of a few seconds.
However, the file holds precomputed data for some two weeks in advance only. After this period, the Tomtom device has to resort to the slow scanning procedure.
You will need to connect your Tomtom device to a PC with the "Tomtom HOME" software installed, available from the Tomtom company web site. Use the software by following the onscreen instructions to update the package "QuickGPSFix" at least once every two weeks and you will find your device much more swift in establishing GPS connection.
Dec 23, 2010 | Tomtom XL 340.S GPS Receiver
How to turn off TomTom gps one 130
Gps 130 is supposed to hybernate only. It is almost impossible to turn it completely off.
Nov 12, 2009 | Tomtom ONE 130 GPS Receiver
Tomtom go720 cant find gps
any number of resons for this. here are a few
Battery is too low to recive a signal
The wrong port is selected in the settings
The antenna is diosconnected or broken
The SIIRF chip is damaged ( connecting to DC car outlet when starting engine)
Battery needs replacing
poor view of the sky
Too far back from windscreen
Too much window tint
First though Take off the faceplate ( using a credit card or similar) locate the reset hole and reset it to factory. Your saved data will be lost ( previous trips data and any skins applied) it may recover and reconnect for you. But charge the battery properly on an AC charger or via the USB.
Please rate my help++++Thanks for using FIXYA
Oct 20, 2009 | Tomtom Go Plus GPS Receiver
Tomtom910 not holding charge or charge properly
Looks like the battery needs replaced. Go to: http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
This site will give yo step by step how to change the battery. Good luck!!!
Oct 03, 2009 | Tomtom GO 910 GPS Receiver
Our tomtom one 3rd edition stopped working it will not switch on or charge up even th ough green light comes on charger when plugged into car
try resetting it, but first put it on the charger for a few hours to make sure its charged. using a paper clip or something similar, depress and hold the reset button located on the bottom of the unit for 15 seconds, then hold the power button for up to 5 seconds till the unit starts.
if that fails, hook your tomtom to your computer and run tomtom home and see if that will update or repair it.
tomtom
let me know if you need further help.
bill
Aug 26, 2009 | GPS
Battery
no it must be the same type as was supplied with the unit. Contact a retailer or repair centre for replacement
Jul 04, 2009 | Tomtom ONE 3rd Edition GPS
Battery will not hold charge on tomtom 300
TomTom will not service tomtoms out of the warranty period. I tried them and they dont . They say / argue that there are many companies offering service . I would suggest that the battery is user replaceable with a little bit of DIY knowledge. You need the correct screwdrivers whicth are Torx type. You can buy them cheaply in sets from size T5 up to T20. First remove screen surround by pushing the windscreen mount clip underneath the tomtom , towards the screen. This will push the surrounf out enough for you to grab the bottom of it and pull it off. Next unscrew the 4 torx screws located in 4 holes around the screen. Next , extract the tomtom 'innards' by easing the assembley out of the front of the case. Next , unscrew the 2 torx screws that hold the speaker in place. Next , remove the 2 smaller torx screws UNDER the speaker. This will then allow removal of the plastic clamp that holds the cylinder shaped battery in place.NEXT , unplug the battery ( theres 3 wires go to a little plug on the circuit board ) and withdraw it through the gap left by the speaker. Fit NEW BATTERY ( available off ebay ) and reassemble in reverse order. Of course all this should be done very carefully. DO NOT RUSH. Work on a clear bench and put something soft on the bench to protect the tomtom. DO NOT force anything , it should all come apart easily. If you are unsure , inexperienced at messing with fiddly things or just plain nervous then get someone else to do it.
Jun 10, 2008 | Tomtom GO 300 GPS Receiver
TomTom has difficulties locating satellites.
Download the latest software tomtom home and do a gpsquickfix. THis will solve the problem and tell the unit where the satellites are for the next 7 days. May need to do gpsquickfix often.
Dec 24, 2007 | Tomtom ONE GPS Receiver
GPS Logo
218 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
