Question about Whirlpool Refrigerators
Whirlpool owners manual WRX28RWH6. The fridge keeps running with few breaks. The frige has a white plastic box at rear, right base. It makes a loud ticking noise. There appears to be a turnable knob on the white plastic box. I wonder if this should be turned, or has been turned causing noise ? We have lst our owners manual which should have described this box & its purpose.
fridgetech
  • 473 Answers
SOURCE: Fridge making a noise
You have a bad relay on the mother board. It is behind a panel on the back of the fridge. You can view a diagram at http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0165000&brandID=0432&modelDesc=REFRIGERATOR%20R%20SERIES&modelNumber=GSH25KGREWW&documentID=G0502132&documentTypeID=PLDM&documentClassCode=PV&titleType=SEALED%20SYSTEM%20%26%20MOTHER%20BOARD&titleID=00008& It is # 801. The part # is WR55X10552 and cost is $124.69 @ http://www3.sears.com/. I replace this board all the time. Make sure to unplug the fridge first!
Posted on Nov 03, 2007
  • 262 Answers
SOURCE: Ticking noise
this is the motherboard part number 2252189 it is getting ready to go out but before you replace motherboard make sure the unit is grounded a bad ground can also make the same problem happen
check ground at wall and all green wires on or around compressor and door hinges
Posted on Dec 07, 2007
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
TheMazz
  • 78 Answers
SOURCE: Fridge making loud screeching sounds
Generally, in my experience, the loud screeching is caused by one of the fan motors or fan blades. There is a fan inside the cabinet (possiblle two, one on the freezer and one on the refrigerator side). Also, there is a fan underneath the unit near the compressor (probably in the back).
If the screeching is coming from underneath then pull the unit out from the wall and remove the cardboard cover at the bottom back. Now turn the unit on and check for where the screeching is coming from.
If it is the fan blade (hitting something) or the motor, you can remove these and replace them easily. UNPLUG THE REFRIGERATOR BEFORE TOUCHING ANYTHING UNDERNEATH THE BACK OF THE REFRIGERATOR.)
Good Luck!
Posted on Oct 28, 2009
localwonder
  • 6784 Answers
HI, This is the result of a damaged Power control board. This board is not regulating the incoming current correctly. This board should be replaced, immediately. This will cause the in-house circuit breaker to blow. The board is located behind a access panel, on the rear of the unit. Have it replaced, soon.
It may be mounted on the compressor platform, as well.
Posted on Dec 22, 2009
Cat number ED25TEXHW00, side by side, Whirlpool Refrigerator. Neither fridg or freezer will cool. Lights turn on & condens fan runs. Compressor will not kick in. What to look for???
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
May 30, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Frigidaire FRT04L5DM works about 1 week then
sounds like compressor is over amping, check condenser coil ,botom of fridge, make sure its clean, also check contactor coil and points, check fan in freezer if it does not blow strong, u will get ice build up, also turn thermostat from cold to coldest and back to see if the compresor and fan shut off by the control
May 22, 2010 | Refrigerators
Whirlpool fridge - WRX28RWH6- approx 10 years old Can you please tell me what the control at the back of the fridge is for (where the electical cord is) - the control has broken off. Fridge seems to work...
Most likely it is for temp control? hard to say without being there.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2010 | Refrigerators
I bought a Whirlpool WD5002D side by side fridge and a Flojet bottled water dispensing system because here water is not good to drink, but I can't find where is water entry in fridge back. Can somebody...
In the back at the bottom right , unscrew white plastic cap, after the beginning of the electric cord.
We already had the water installation with filter and pressure according to manual.
Jan 04, 2010 | Whirlpool Refrigerators
Doors need levelled - motor runs very loudly but is silent when fridge door is opend - Can you send instructions as to how to level the doors?
the door leveling is controlled by the front legs on the bottom of the frige. make sure the frige is level first.
Oct 29, 2009 | Whirlpool GS5SHAXN Side by Side...
Lights in fridge side are all out. After changing bulbs, sounds like a relay sticking and will knock out all lights in fridge unless we loosen off the bulbs in the fridge side
your main control board Part#4334000 is defective in lower left rear of unit remove it from the white plastic box and underneath it will have a burned spot on the printed circuit trace get it at appliance parts pros 1-877-477-7278
Sep 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Changing interior light bulb in Whirlpool Frost Free 350,390 or 460 (per manual)
Hello davvyde,
Welcome,
You said, you have removed plastic cover for light bulb, as per manual supplied, but I cannot fit my fingers around light bulb to unscrew it. Is it clockwise or anti-clockwise and does the bulb actually screw into the white bayonet, or is that part of the overall bulb-structure? Not enough space to screw anything! Incidentally, I have a small hand and therefore small fingers.
What is the model number of your appliance.
Is the bulb intact or did the glass part come off and leave the metal base inside?
IF YOU HAVE A PROBLEM TURNING OR GETTING THE BULB OUT, BEFORE YOU US ANY THING OTHER THAN YOUR HANDS, UNPLUG THE FRIDGE!
  1. Whirlpool bulbs screw out counter in the counter clockwise position.
  2. If it is screwed in very tight try a rag, or towel in your hand.
  3. Or you may try a rubber glove which causes friction and may give you a better grip.
  4. Turn off the fridge for a moment while you do this, in case the bulb breaks in your hand
  5. If the bulb comes apart from the metal base, (AND YOU HAVE THE PLUG OUT OF THE OUTLET) You may be able to gently use a needle nose pliers, to little by little loosen the bulb up if it is stuck
I've never seen this before in a fridge.
Let me know what works?
Huuum
Please remember to leave a rating!!!!
Oct 14, 2008 | Whirlpool Refrigerators
Knocking noise
I got the Same Exact problem with my S2OD RBB32-A/G Whirlpool Ref.
its has a Fast and Random Clicking on the Back in its Motherboard (White Box), i Open the main Board and it seems that its a Relay Who is Going Crazy!
it started to happen for 5 min then last couple of month then its now lasting for 2 and 3 hours!! after this it t works normal, then when the Electricity goes off than On again the Hole cycle accrue over and over.
Also When i Open the Door of the Fridge the clicking stops then comes again when i close the door!
Any Help?
Sep 09, 2007 | Whirlpool S20DRSS33 Side by Side...
Refrigerators Logo
374 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
