Question about Panasonic SC-PT960 Theater System with Wireless Speakers
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I only use it for surround sound but I cannot use it for anything while this is going on. Please help!
Hi! the chgr err code indicates one of you trays is stuck inside the dvd tray unit. this occurs typically when the reader is initializing the last disk viewed and you push the exchange disk button. This happened already twice on my system. I did solve the problem by opening the unit and removing all components until I could access the trays and manually release the mechanism. I only recommend doing so if the player is out of warranty and if you are not afraid on working with small electronic/ components parts. I could not find any other non-invasive solution to the problem.
Posted on Aug 30, 2010
  • 2 more comments
  • ashleydz Aug 31, 2010
    I am having the same problem....i also opened the unit up and was tinkering around with it. What did u manually release for it to begin working again? The "eye" the reads the disc goes all the way to the back and then clicks and clicks for about 4 seconds. I dont understand what it is catching on?!?!
  • loreb Sep 01, 2010
    Have you removed the white plastic cover on the disk unit? Once removed I was able to notice the disk was avoiding the tray to move freely and in my second instance the moving mechanism linked to the' eye' had the lever that pulls in the tray not in its proper position. By disconnecting manually the 'arm' from the tray and turning on the unit the system reset.
  • ibrubeer Sep 07, 2010
    My unit was doing the exact same thing. I couldn't see what it was catching on either. I took the white plastic cover off the disk unit, and could see the parts and trays moving, but it didn't appear to be catching on anything. Finally, it started working again. I have no idea what I did, but something must have been stuck and I nudged it enough to start working. I know this doesn't help much, other than to suggest keep tinkering with it and wiggle the parts that move? Good luck.
  • Brandi Maciad
    Brandi Maciad Feb 08, 2018
    Im having the. Same problem but it's stuck in am\fm and won't change at all
    New Friend:
  • 95 Answers
Check this web site, may be will find some parts.
Posted on Mar 17, 2015
3 Suggested Answers
  • 910 Answers
SOURCE: I have a Panasonic SA-PT960
There is a fault with the DVD Changer and the noise is the gears grinding. This is a common fault with these units as a small arm within the unit breaks and blocks the mechanism.
You can either try and replace the complete DVD Changer or remove it and just us it as a surround sound system with your auxiliaries connected to it.
Posted on May 09, 2011
SOURCE: I have a Panasonic SA-PT960 surround sound/dvd
what did u do? I have the same problem and I am hoping that I can still keep the speakers and replace the DVD. I called Panasonic and they said I shld take it to the nearest service center and they said no replacement. I dont want to buy a whole new system, what did u do?
Posted on Sep 07, 2010
How to connect a blue ray player with the sc pt760 sound system with dvd?
According to the models you provided it looks like the DVD player has only HDMI out and the sound system you have does not directly support that. I would suggest purchasing a HDMI audio extractor so that you can covert the digital signal from your blu-ray to an analog signal. However, there are other ways of doing this. If you provide me with your TV that you use I might be able to advise another work around.
Go on google and look for "hdmi audio converter" or "hdmi audio Extractor".
Make sure to look at review to determine the quality of the product and decide what device fits your budget.
Nov 23, 2015 | Panasonic...
DVD changer is jammed on my Panasonic Sa-pt770 Receiver
if you have 2 tiny screw drivers, if not, the tips of a butter knife might be skinny enough, you can try to insert them a wee bit into both sides of the tray and pry outward, carefully of course, and unjam the tray
Mar 09, 2013 | Panasonic Sa-pt770 Receiver Only For...
Model SA-PT960 says chgr err
Can be a fault on the mother board as the fault seems to be linked to two issues. The failure of the loading drive and also a failure in the system control.
Unless the unit is opened up and checked the exact fault cannot be confirmed. Sometimes itt can be a jammed drive, faulty motor or drive or a dirty optical lens.
Nov 12, 2011 | Panasonic Televison & Video
May 09, 2011 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SA-PT960 surround sound/dvd player. Whenever I turn it on I get a chgr err flashing on the screen and a loud grinding noise. I cannot use it for anything while this is going on. Please...
Aug 18, 2010 | Panasonic SC-PT960 Theater System with...
I have the panasonic SA-PT960.W1 keeps flashing and the disc changer says CHGR ERR
I have the panasonic SA-PT960.W1 keeps flashing.when it stops no sound from wireless speakers
Oct 26, 2009 | Panasonic SC-PT960 Theater System with...
I have a err code "chgr err" on my panasonic sc-pt960.
This would indicate a CD/DVD Changer Error.
The system thinks there is a stuck disc or other wierd problem with the CD/DVD changer.
Unfortunately these issues are rather hard to fix, due to the way the changers work.
Opening these units isn't that hard, however fixing an issue with the changer is very difficult and is best left for a specialist.
You may need to contact a local Panasonic repairer to get this one fixed.
Use the link below (if you are in the US) and enter your model number and ZIP code to locate your nearest repairer.
http://www2.panasonic.com/consumer-electronics/support/?cm_sp=Homepage%20Support-_-Header%20Support-_-Support%20For%20Customers%20Link
Best of luck, and sorry that I could not be of much more help than this.
Jun 22, 2009 | Panasonic SC-PT960 Theater System with...
Sc-pt760 "chgr err"
For panasonic sc-pt760, if the DVD player is busted, you can't access the option to switch to Digital in. With Digital in, you can still use the unit as a sound system by feeding it through the optical input from your TV.
but, the trick, You can't access the switch menu without an ipod. For some reason, you can switch from an Ipod to your D-in. You can't switch out of AM/FM to d-in as it tries to access the broken DVD first.
Jul 02, 2008 | Panasonic Home Theater System System
Panasonic SC-PT960 Theater System with Wireless Speakers Logo
3,525 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
