Question about Sharp XE-A404 PC Desktop
I have an E36 error message on the register. I press C and retry but error comes up again.
My printer error message indicates- Alignment problem.(1) Remove tape from cartridges.(2) Check Paper.(3) Press Ok to retry. I do not see it being easy to remove tape from cartridge,but my allignment paper...
Make sure you are using the correct cartridges for your model. Try to remove both the cartridges. Close the cover. Unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Close the cover and check for any error. If none, try to print again.
Apr 11, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Please help uninstall
Try starting in Safe Mode and then uninstall it.
(press F8 during boot).
Jan 24, 2009 | IBM Lotus SmartSuite for PC
Cannot synchronise the balance board
Make sure that the batteries in your Wiimotes are fresh. To know, when you start up the remote for the first time, the number of blue led lights blinking indicate battery life. With only one light blinking (or none), it's time to replace your batteries.
Jan 11, 2009 | Nintendo Wii Fit for Wii
Unable to sync Balance Board and its knocking the remotes out too
When you are prompted to press the sync buttons you just have to press and release just once the sync button on the console and then on the board. Do not hold the buttons in because you just end up un syncing everything!
Dec 27, 2008 | Nintendo Wii Fit for Wii
E026 error message Casio TK-7000
find out what plu it is then re pgm it
turn the key to PGM
enter 3 & press Subtotal
enter 0166 & press Subtotal
enter 0 and press the faulty PLU
now press Subtotal
enter 1066 & press Subtotal
now press Subtotal
turn the key back to Reg
Dec 23, 2008 | Casio Parts Cash Register PC Desktop
Sharp XE-A203 Cash register Error message 3.2
You have logged yourself out of the machine. Press CL then 1 then CLK# or CASH#
Dec 13, 2008 | Sharp XE-A404 PC Desktop
Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
No Link to Base
to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
Sharp XE-A404 PC Desktop Logo
135 people viewed this question
Top Sharp Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
