Question about AEG Lavamat 72640 Front Load Washer
Aeg l 72640 e034 what is this - AEG Lavamat 72640 Front Load Washer
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
E34 is listed on the 72630 as a conflict between the 2 water level pressure switches. A simple solution can be a blockage in the pressure chamber that the 2 pressure tubes attach. a faulty pressure switch or a more likely miss reading of the level control by the electronic. You need to be able to configure a new electronic to fit it . not a diy job.
all the e3x errors relate to water level problems.
Posted on Jul 20, 2010
I have an AEG 72640. It is taking the fabric conditioner in the 2nd rinse instead of the last and the clothes are not coming out smelling of fabric conditioner. How can I solve this?
Hi. The problem will be one or more of the holes in the top of the soap dispensor (view with drawer out) will be partially blocked causing water to squirt into to one side and fill softener compartment. Dont overfill with softener stay below max level. Holes are not easy to unblock use large paper clip ,bent to allow you to poke holes clear.
Jun 21, 2012 | AEG Lavamat 72640 Front Load Washer
My 72640 AEG washing machine continually leaks even though the filter cap is tightly in place. What could be the problem please? Kate Comins
you have a hole in the rubber boot seal and need to change it,also i've seen a buildup of detergent and hair stuck on the bottom side of the front door,when the door is closed the water was traveling down the pieces of hair and leaking through the bottom of the door,but if it's leaking under where the pump is and it's not the pump or hoses it's the boot seal.open the door and pull open the boot seal and run your fingers all around until you find the hole
Jan 23, 2011 | AEG Lavamat 72640 Front Load Washer
About mid cycle, a significant amount of water leaks out of the bottom. No error message comes up and the machine continues functioning. Machine is AEG oko lavamat 72640
Could the machine be overfilling due to a faulty pressure switch (controls the amount of water in the drum). Splits in the door seal or broken pipes?
Jan 25, 2010 | AEG Lavamat 72640 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG WASHING MACHINE
fit hoses at random. put on a rinse cycle. if cold water comes in then hoses are correct. if hot water comes in, then reverse hoses
Aug 22, 2008 | AEG Lavamat 72640 Front Load Washer
Aeg washing machine
Click on 'washing machines' (below FIXYA) on this website, & search witrh your model number. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
May 30, 2008 | AEG Lavamat 72640 Front Load Washer
AEG 72640 update
e20 means cant drain i usually found itsufficient to clean filter and restart but this time i blew down waste pipe /drain,cancelled program and reset
Jan 13, 2008 | AEG Lavamat 72640 Front Load Washer
AEG 72640 Washing machine
Try:
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | AEG Lavamat W1450 Front Load Washer
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 72640 Front Load Washer Logo
388 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
