Question about Dryers
I have a Maytag Neptune dryer that has one of the agitators? that have come loose and am trying to figure out how to get to it to tighten it back up. It's an MDE5500AYW. Thanks
    Novelist:
  • 184 Answers
THE FRONT OF THE DRYER IS REMOVED BY OPENING THE DOOR AND REMOVING THE TWO SCREWS HOLDING THE HINGES TO THE FRONT PANEL. ALSO, REMOVE THE TWO SCREWS ON THE OPPOSITE SIDE OF THE OPENING. PULL THE FRONT PANEL TOWARD YOU AT THE TOP. IT WILL BE HINGED AT THE BOTTOM. ONCE YOU HAVE IT TILTED TOWARD YOU, PICK IT UP OFF THE BOTTOM HINGES.
THERE ARE TWO RETAINING CLIPS HOLDING THE TOP DOWN AT THE FRONT CORNERS. THESE CLIPS ARE HELD ON BY A 5/16TH HEX HEAD SCREW. REMOVE THE SCREW AND CLIP AND YOU CAN LIFT THE TOP. IT IS HINGED AT THE BACK AND YOU CAN RAISE IT UP AND BACK OUT OF THE WAY. YOUY NOW HAVE ACCESS TO THE OUTER SIDE OF THE DRUM. ROTATE EACH OF THE BAFFLES TO THE TOP AND TIGHTEN EACH SCREW AS THEY COME TO THE TOP.
Posted on Apr 22, 2008
One of the dryer fins is very loose. How do I tighten it?
REMOVE SCREWS FROM DOOR HINGES AND OTHER SIDE REMOVE DOOR THE FRONT DOOR CLIP REMOVE CORNER BRACKETS LIFT UP FRONT LID AND TIGHTEN SCREWS ON FINS
Jan 25, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a maytag neptune dryer and the drum is loose how do i tighten it?
Why do you say that the drum is loose? Are you able to wobble it by hand? If so, that is evidence of a bad roller that the drum sits on.
If the drum doesn't turn as fast as it did, that is probably a loose belt, which would indicate that the belt tensioner is not working or belt has jumped the tensioner.
Jun 13, 2010 | Maytag MDE2400AYW Neptune Electric Dryer
Neptune Dryer Blades
Yes - right where the front panel meets the top panel of the dryer on both sides there are two clips. Insert a screwdriver into the clips and push up on top panel. You'll see the screws that hold the fins on the dryer. Tighten these screws or replace. Good luck...
Nov 16, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose paddle
Pop the top ... remove the front ... carefully remove the belt ... take the drumout - you are correct, the paddles are held onwith screws - tighten them.
reassemble
Oct 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Is there a problem with Maytag Neptune Dryer Drums. I have a customer who had one agitator fall off while doing laundry. I was called to make a vent repare and found the aluminum elbow attached to the...
i have repaired several of these simply locate the screw that fell out at the interior bottom of the cabinet and screw it back onto the baffle this is pretty common
Oct 08, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose fins
Hi, Unplug the dryer. Remove the screws on each side of the door opening. The front will pull toward you and lift off the clips at the bottom. You have the option to take the door off or leave it hang there. With the front off, you should be able to reach in and tighten the screws that hold the [addles in place. Just turn the drun by hand to get to the next paddle. You will need a 5/16" or 1/4" nut driver/socket.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 19, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose shelf in Maytag Neptune dryer
Hi, UNPLUG the dryer. There are two screws on each side of the door opening. Remove them screws and the front should pull toward you and release.The door can either lift off or remain on. You can reach under the drum and tighten the screws.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune MPG5500AWW loose baffles but can't figure out how to lift top or front
Press a putty knife in at the top front corners. That will release the spring catches.
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
