Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Forgot how to change ink
How do i change cartridge on sx215 printer
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the lid that covers the print-mechanism.
In a few seconds, the cartridges will slide to a place where you can easily remove them, and insert a replacement cartridge.
Close the lid.
Posted on Jul 20, 2010
    New Friend:
HAVE INTERMEC 8 T FORGOT HOW TO PUT INK CARTRIDGEIN
Posted on Mar 11, 2013
3 Suggested Answers
merbuquis358
  • 94 Answers
SOURCE: how do i change my ink cartridge on the epson
Click on the start menu then go to Printer and Faxes. After that go to your default printer Epson SX215 and right click the printer then click properties. Dialogue box was appear click on the maintenance and then click replace cartridge their was a dialogue box will also appear. Just click the next button and read the instruction when you press the Next button. After that open the cover of your printer when the cartridge are at the center that's the time you can change the cartridge. Then close the cover when you're finished to change the cartridge. Then click the next button and so on to finish.
Posted on May 29, 2010
SOURCE: Epson Stylus SX215 the ink cartridge holder won't
its because the ink housing will only aline when the ink is empty its not like any other printer that you can line the housing up. Wait until you run out of ink then lift up the lid and the housing will be alined - its stupid system and epson dont tell you this when you buy the produc
Posted on Feb 22, 2011
How do I change the ink cartridges on an EPSON STYLUS Sx215
Hi joanmcd2, Just go to control panel and go to (printers for xp)/(device and printers win 7) open the properties of the driver and goto Maintenance tab and then click the EPSON Status Monitor button, you will see the ink levels and there will be an option to replace the ink.
for details pls dwonload the Sx215 manual on this link
Aug 05, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Cannot change ink cartridge on epson stylus sx215. Need advice in plain english - some of the solutions already offered I cannot understand!!
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartridge". the ink cartridge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jul 04, 2011 | Office Equipment & Supplies
Printer (epson stylus sx215) wont recognize generic ink cartridge
- try to repeat a remove and replace all cartridge. with the careful and pass.
- if it does not changed, try to reinstall driver,s
good luck .......
Jun 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Sx215 ink carrier will not stop at correct place to allow me to change black ink
Let it there where it has arrived by itself, unplug the printer from the mains, gently but firmly move the carrier to the correct position, change the ink cartridge and close everything.
When the printer will be plugged in and started the carriage will return to its normal position.
Jun 03, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i change the ink in my epson stylus sx215?
  • Select "menu" and "setup mode"
  • Select "maintenance" and "change ink cartridge"
GOOD DAY
BOBUS
Feb 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have bought epson sx200 ink instead of sx215 will this still work as if not i will have to return it unopened???
Just have a look at the generic cross reference chart for aftermarket ink jet cartridges & you will see the one cartridge suits ten different Epson models
BLACK >>> T0891 Compatible; Ink contents 19ml
Stylus S20, S21, SX100, SX105johncsuk123
Stylus SX200, SX205, SX215
Stylus SX400, SX405, SX415
Jan 07, 2011 | Epson Office Equipment & Supplies
Epson Stylus SX215 the ink cartridge holder won't move into position so I can change a cartridge
Jan 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do i change my ink cartridge on the epson sx215 printer
May 29, 2010 | Epson Office Equipment & Supplies
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
433 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
