Question about T-Mobile MDA
Unlocking my mda phone
I forgot the password to my handset.and i want to reset it but am afraid ill lose all the info on the phone
  • 3 more comments
  • mperalta428 Apr 22, 2008
    forgot my handset password how can i get in to my phone without erasing all of my info
  • pmills Apr 29, 2008
    i locked my mda and forgot my password.
  • godsgrace Jun 27, 2008
    changed my password, and formed it to lock on the hour if not used. Now, I can't get my password just right, lower case, upper case, numbers, something is not going right. I can't call out on my phone
  • courtney97 Jul 07, 2008
    i forgot my password to my phone and cant get to the information in the phone
  • ziniajohns Jul 12, 2008
    Stupid, i know but i lent my daughter my MDA and she cant remember the 4 digit code she put on the phone............. any suggestions on how i can reset it so i can get into the phone. I thought of a hard reset (tried a soft reset... doesnt work) but dont i have to be able to get into the phone to do the hard reset............ any help would be appreciated
    thanks Zinia
    New Friend:
  • 166 Answers
Go to www.xdadevelopers.com website they have small program very easy to solve your password problems
Posted on May 12, 2008
How can I unlock screen without doing factory reset?
Juan, You have to remember your pass code.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Check the attached links,instruction and guides, Good luck
have forgot the screen unlock PIN code of my HTC how can unlock it now
What to Do If You Forget Your Android Phones PIN Pattern or Password
Reset Samsung Galaxy S2 S3 S4 Note2 Note3 Without Losing Data
Reset Android password without losing data
Mar 19, 2016 | Samsung Galaxy Core Prime G360M/DS -...
Forgot the unlock patern for my zte muve music model# D930
Reset your phone it will unlock. Ill tell u how,
First power off the handset, and press the POWER key + MUVE key + UP Volume key together at the same time
When the screen displays recovery pattern, press POWER key + UP Volume key _MUVE key together,
Enter into recovery menu Choose wipe data/factory reset through volume up key,
press MUVE key to confirm Then choose YES...delete all user data through volume up key
Choose reboot system now, handset will be restarted automatically and all the user data will be erased.
(ALL THE DATA ON UR PHONE WILL BE LOST THOUGH)
Mar 04, 2013 | Cell Phones
I forgot my pattern password now i have to sign in using my username(email) both of which i don't have how do i get back into my phone?
If you forgot you screen unlock pattern then you need to reset it. The simple procedure is mentioned below -
    1. Continue to enter the unlock pattern five times until you are prompted with forgot password (forgot pattern in some handsets) at the bottom right side of the screen.
    2. Tap on the Forgot Password option and you would be prompted to sign in with the existing Google or Gmail account information. You need to provide the ID when you first register or activated your phone. If you have that, it would be easy to get in for you and then change the unlock pattern (atleast by now you would be remembering your unlock pattern).
    3. If you don't know the Gmail ID or the password is wrong then there is only one solution to hard reset your handset. The data present on the added SD card will not be wiped out but you would lose your personal data or information or contacts stored on your phone memory.
    4. The procedure for hard reset is mentioned clearly at reset the mobile.
  1. F150 Parts.
May 27, 2012 | HTC Wildfire S Smartphone
I forgot my phone password
this happens all the time with samsungs. i went to tmobile.com/forums and found some info to fix mine when i forgot mine as well lol. the problem is it will reset your password and all your other information as well :(
A phone lock or security code on most Samsung handsets can be overridden by performing a full reset on the device. This will set the security codes on the handset back to the default eight zero's (00000000).
Important: This reset restores the original factory settings and will erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. It does not erase data stored on the SIM card or memory card (if available). Make sure you have backed up contacts, calendar appointments, and other data before continuing.
1. Power off the handset
2. Remove the battery
3. Remove the SIM card
4. Reinsert battery ONLY
5. Turn handset on
6. At the Insert SIM prompt screen enter the following code: *2767*2878#
NOTE: If using a handset that was released after July 2009 use this code: *2767*3855#
7. The handset should display E2P custom reset
8. Power off handset
9. Reinsert SIM card
10. Power on handset
11. The phone should be unlocked
NOTE: If you didn't get a E2P custom reset or a Full reset message on the handset your Samsung model may need an MCK code. You will have to call technical support for this code. Please have your IMEI number ready to expedite the process for this code. Your IMEI number is located on a label on the back of the phone,under the battery.
Dec 24, 2010 | Samsung C3510 Cell Phone
My samsung GTS 5620 is locked and i am unable to open any application as i forgot the password. i have tried the default passwords such as 12345, 00000 etc and it still says password incorrect. Is it...
A hard reset is the only solution I'm afraid. You will lose all data as a result of this. If you could access the dialer enter *2767*3855# and press the call button.
Dec 29, 2017 | Samsung Cell Phones
I forgot my password. how to unlock my t-mobile mda?
i forgot may mda password how to unlock
Jan 04, 2010 | T-Mobile MDA
Samsung SGH a727 forgot password to turn on phone
To reset the handset, to the factory default settings, follow the steps below:
  1. While in standby mode, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Reset Settings (10)
  4. Highlight, using the navigation keys, any of the following:
    • All: Phone, Display, Profile and Alarm settings will be returned to default values
    • Phone Settings: only phone settings will be returned to default values
    • Display Settings: only display settings will be returned to default values
    • Profiles: only profile settings will be returned to default values
    • Alarms: only alarm settings will be returned to default values
  5. Press the center navigation key to check the box(es) of reset settings
  6. Press the left soft key for OK to set the Reset
  7. Enter the password, using the keypad, default password is “00000000”
  8. Press the left soft key for Confirm
  9. Enter the password again to confirm, using the keypad
  10. Press the left soft key for Confirm
  11. Press the left soft key for Yes to reset the handset's settings to the factory defaults
Sep 25, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Forgot my keypad unlock code
i have a sprint pocket pc-6700 i forgot my keypad password how can i unlock
Apr 11, 2009 | RIM BlackBerry Pearl 8100
Password mda
I would definitely connect to a computer, then copy everything to a folder. Even if you have to reset your phone, you can always put your data back in later.
Aug 28, 2008 | T-Mobile MDA
T Mobile MDA Speaker control
Update teh firmware from tmobiles website. Download the latest firmware and upload it to your mda... Should fix it.
Aug 01, 2007 | T-Mobile MDA
T-Mobile MDA Logo
151 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
