Hi. the Korg Radias is Korg Rasias RD-KB.it have the usb-mididriver version for windows 1.06,and the sound editor for windows 1.00. my computer is emachines R3350 2.8Ghz 256mhz ddr sdram x2. Tore
    Guru:
  • 528 Answers
Hi. May i know what is the exact problem here for me to assist you with your concern?
Posted on Jul 20, 2010
  • 6,993 Answers
this is not a question. You have only listed/stated the specification of your Korg. May I know actually what the problem is or is there something your re trying to verify?
Please let me know so that I can help you out.
I look forward to your reply.
Bye for now.
Unlocking disc for sounds
Probably your best bet is to use a sound editor/library. Move the sounds onto your computer, then into the librarian editor, then from there through midi into your keyboard.
Sep 16, 2017 | Korg Music
I copied a file in a work computer into my USB and my USB become write protection and i cannot copy any file into it since
I belive the write protcetion is based on your computer and not the USB drive unless you find a write lock on the actual USB drive. If not, then you can disable Write Protect on your PC... To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>.
    2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
    3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled).
    4.Close the registry editor and restart Windows.
    5.After Windows starts, test writing to your USB drive.
    Important Note:
    Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored.
    For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
Mar 10, 2014 | Electronics - Others
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I have a kingstone 2 GB data traveller. But I don't have its driver for using it in windows 98.
Download the driver and install it.
http://www.technical-assistance.co.uk/kb/usbmsd98.php
Installing the drivers system98.gif Before installing the drivers, it is important to know that there are 2 main versions of Windows 98, and they both handle USB differently. You must install the appropriate version of the drivers dependent upon your version of Windows 98. In order to determine your Windows version, please do the following:
  • Right click on My Computer and select Properties
  • On the System Properties page that opens up click on the General tab, if it is not already on that page.
  • Under the System heading, look for the version number (see right)
    • Version 4.10.1998 is the original version of Windows 98 (98FE)
    • Version 4.10.2222 is Windows 98 Second Edition (98SE)
  • Click the link below for the download and installation instructions for your version of Windows 98
http://www.technical-assistance.co.uk/kb/win98fe-usb-mass-storage-drivers.php
http://www.technical-assistance.co.uk/kb/win98se-usb-mass-storage-drivers.php
Dec 25, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I need mercury 865 motherboard sound driver for windows 7
Drivers Version Specification Size Note Download
A3.69 Audio Driver_Realtek 23.7 MB
dl_bu_dl.gif V3.6 LAN Driver VIA 823X 4.07 MB
dl_bu_dl.gif V1.0 VGA Driver 14.1 MB
dl_bu_dl.gif V4.55 VIA IDE DRIVER 1.41 MB
dl_bu_dl.gif V4.12 VIA SATA RAID Driver 6.93 MB
dl_bu_dl.gif V1.0 VIA USB Driver 3.03 MB
BIOS Version Specification Size Note Download
V1.0 050818S-BIOS 510 KB
Manuals Version Specification Size Note Download
V1.0 User Manual 356 KB
Dec 12, 2010 | Mercury P4VM800M7 Motherboard
My sound driver is not working properly.After reinstalling windows xp sp3(clean install),i couldn't hear the sound.The device Manager is showing Multemedia and Audio controller and could insatll the driver...
Go to the web site of what ever PC you have ( Dell, HP or what ever the PC is ). At the web site you should find section that says drivers and support, or something like that. It will have you select your make and model. You should find the correct drivers there.
Hope this helps.
Good Luck
cookEmonster
Oct 17, 2010 | Intel Computers & Internet
Error Code: 0x80070002
I think The default security provider in Windows XP has been changed loadTOCNode(2, 'workaround'); To reset the default security provider in Windows XP, delete the relevant registry keys in the Windows registry. To do this, follow these steps:
  1. Start the computer. Press the F8 key during startup to start the computer in Safe mode.
  2. Start Registry Editor (Regedt32.exe).
  3. Delete the following registry keys in the Windows registry: HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptography\Providers HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptography\Providers
  4. Quit Registry Editor.
  5. Restart the computer
Jun 02, 2010 | IBM ThinkPad A21m 2628 Notebook
Problems to make the sony icd-sx25 software editor recognize my hardware when i connect to pc with usb cable. using a windows vista home premium 64 bit operating system
There is Sony Digital Voice Editor Version 3.2.01 available to work on Windows Vista Home Premium 64-bit.
Click Sony Support to download "DVESetup_EN_3201" file (size approx 83MB) and install it in your computer, this will solve your problem of ICD-SX25
Thanks.
Jan 29, 2010 | Sony ICD-SX25 Handheld Digital Transcriber...
Everytime I try to download certain software that uses MSI, I get this message. "Windows has the following information about this file type. This page will help you find software needed to open your
Hi Princess Tina,
It sounds like the registry keys needed to recognise and open msi files are missing or incorrect.
Paste the following into a new file (eg. with notepad) and save the file with a .reg extension. setupmsi.reg will do ok. Then double click on the saved reg file and add the keys to your registry. (The first line "Windows Registry Editor Version 5.0" must be the first line in the file).
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.msi]
@="Msi.Package"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package]
"EditFlags"=hex:00,00,10,00
"FriendlyTypeName"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,\
00,6f,00,6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,\
32,00,5c,00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,34,\
00,00,00
@="Windows Installer Package"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\DefaultIcon]
@="C:\\WINDOWS\\System32\\msiexec.exe,0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell]
@="Open,Repair,Uninstall"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Open]
@="&Install"
"MUIVerb"=hex(2):40,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,\
6f,00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,\
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,36,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Open\command]
@=hex(2):22,00,25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,74,\
00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,6d,00,\
73,00,69,00,65,00,78,00,65,00,63,00,2e,00,65,00,78,00,65,00,22,00,20,00,2f,\
00,69,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Repair]
@="Re&pair"
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,37,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Repair\command]
00,66,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Uninstall]
@="&Uninstall"
00,6d,00,73,00,69,00,2e,00,64,00,6c,00,6c,00,2c,00,2d,00,33,00,38,00,00,00
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\Msi.Package\shell\Uninstall\command]
00,78,00,20,00,22,00,25,00,31,00,22,00,20,00,25,00,2a,00,00,00
Good Luck and don't forget to leave a rating,
Thanks Mark
Apr 23, 2009 | Computers & Internet
Computers & Internet Logo
91 people viewed this question
Alun Cox
David Payne
David Payne
