Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JD 855 the idle spring broke and th hydrostatic pedals would not return to their neturel position . before I new what had happene I pushed the reverse and the tractor lunged backward then I pushed the forwrd pedel and the tractor lunge forward. at that time I slamed the brake pedl that is at the forward and reverse pedal. the tractor stoped. and I turnedit off. I replace the spring nd relized the forwar and reverse pedels are not connectd to the idle spring. the tractor brake will not release and the linkage that connects the pedals seames to be disconnected behinde the framealo the tractor will not turn over to start like ther is a safty circuit that will not alow the tractor to start.
  • 2,272 Answers
Yes there is a safety switch.And this safety switch has to be engaged.If its not engaged then the JD tractor will not start. On JD 855 the safty switch is located under the seat, There is a rod that must be depressed before engage Somehow that rod is bent or its not pressing the switch to the point that the seat would not fully engage the safty switch.In some cases the switch itself is faulty.It has to be checked . Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 20, 2010
  • gary_h_hamil Jul 20, 2010
    The problem is that the tractors forward and reverse pedals have no pressure they will not return to the normal position. and the rear wheel is locked and will not turn even though the tractor transfer case isin the netural position. The swithc under the seat has been checkde and keeping the tractor from starting.
How do I put the throttle trigger back together?
Hi Myles:
Since I don't know your machine, I can only give you the logic that I would follow if I were given your box of parts.
- The springs are intended to return the trigger to the idle position.
- With the motor off, Move the trigger from idle to full on, then back to idle. That's what is upposed to happen with the spring pulling it back.
- The other spring is connected to a governor. that is sometimes a "vane" that gets air from the blades on the flywheel, but the idea is that when th engine is under load, more throttle gets applied.
Consider it a fun project in logic.
Play with it, and all of a sudden all of the bits will be right and you'll be cutting grass like a mad thing.
Cheerfuls.
Nov 26, 2015 | Garden
Ow do I tighten the belt on the mowing platform
Most JD mower decks use a spring loaded tensioner on their belts. Make sure that the belt is threadded thru the pulleys the right way and you may find that considerable effort is required to set the tensioner in position. Be very careful to ensure that if the grip slips the spring flies away from you. I use the hook on a cargo strap to pull mine into position. Normally there is a similar tensioner on the drive belt for the wheels. This is more challenging to get to.
Sep 28, 2014 | John Deere D130 22HP V-Twin Foot Pedal...
Why won't my car idle
sounds like the throttle/ accelerator cable is stuck or the return spring broken. open the bonnet (hood) and observe the carureta whilst some one presses the accelerator.does it move back and forth with the pedal? check for kinked cable, lubricate cable. had return spring broke?
Sep 13, 2014 | 2000 Chevrolet Chevrolet Malibu Base
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Car won't start. Gas pedal goes to floor with no feel to it.
If i am understanding your question correctly, when you push your gas petal down, there is no resistance to it or very little. If this is the case, I would raise the hood and track the linkage to the intake throttle body. there should be a spring on it to return the accelerator to the idle position. you may also look under the dash board above the gas petal as it may have a spring as well that will return it to the idle position.
Dec 14, 2012 | 1996 Dodge Intrepid
After engaging the clutch pedal, it won't fully spring back to normal position.
There is a spring on the clutch fork which resists pushing the pedal and returns the pedal to its proper rest position. It would be on the bell housing where the slave cylinder is attached. Possibly that spring has broken, and hopefully you can replace it without pulling the bell housing off the engine block..
Oct 28, 2010 | 1991 Isuzu Stylus
Clutch pedal not returning to position
Under the dash look to see if there is a spring attached to the petal or maybe under the hood. Or you might have something getting in the was of the petal arm. Good Luck and PEACE
Jun 13, 2008 | 1987 Ford F 150
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
595 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
