Question about Dell OptiPlex GX280 PC Desktop
Hi my computer dell gx280 didn't work. It keep show "no boot device available". i try to replace with new hard drive but it still show same thing. Can you help me figure out what is problem with it please?
    Scholar:
  • 77 Answers
Thank you for question.
In this instance it is easier to point you in the direction of Dell's support page. I have provided the link and the information you require is approximately half way down the page "Reinstalling Windows XP"
http://support.dell.com/support/edocs/systems/opgx280/en/ug/reinstal.htm#1182201
Best of luck with your install.
Kind regards
Posted on Jul 20, 2010
  • 487 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Try the above solution and let me know how you get on?
I cloned a 300GB XP boot drive on a 4GB Dell GX280 to a 500GB HD on a 1GB Dell Dimension 5000, but even in Safe Mode, when I try to start up from the 500GB, I get the 0x7b BSOD...
the 7b is a hard drive controller issue the controller on one computer is not the same as the other. maybe try the ultimate boot cd to clear the problem
Nov 26, 2015 | Dell GX280 Optiplex 2.8GHz Desktop...
Ok i have two hard drives and the computer is not finding them
poss windows has fallen over you need an operating system check hdd are master and slave master first one from board go to bios set the cdrom as the default 1st boot device put operating system into cd rom should start to load operating system
Apr 06, 2012 | Dell Inspiron 530 Desktop Computer...
My Dell System GX280 would not come on. I thought it was the power supply, which is built into the computer, so I got a new power supply (a general one that's worked on all my past computers from
Test the leads that attach to your ((hard drive from the motherboard)) make sure they have dust free secure connections or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) if its a 40 pin IDE this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs continue its cycle power and data to travel through every working device and have an end point so any faulty leads will end up with a computer error
hope this helps you
Feb 28, 2012 | Dell OptiPlex GX280 PC Desktop
My Dell computer was corrupted with a virus. and I went to f12 to re-install it. but it keep saying 'Boot device net available, I have a Dell XP 8400, can u help me? Will there be a charge?
Hi there.
Enter the bios setup menu and make sure in the Boot section under Hard Drive Priority, that the boot device is set FIRST in that area. Just make sure the hard drive that you need to boot from is set at the top of that list.
Let me know what happens.
Thank you!
Aug 08, 2011 | Dell Dimension 8400 PC Desktop
My dell 5150 dimension will not boot up and says no boot device available. I have gone into system setup and tried a few things and at one point got a message that said drive 0 not found and now it is back...
Go back to setup and check your boot sequence. It may not be looking for your hard disk. Do you know what Hard disk you have? It may not be wired in there properly if it's in the boot sequence. Set DVD/CD to 1st boot device and put in your installation disk. Do you boot now? Do you have data on your hard disk you need? If not, Re-format the drive.
Nov 07, 2009 | Dell OptiPlex GX280 PC Desktop
My Dell Optiplex 745 "No Boot Device Available"
No boot device means that the computer cannot find a drive that has a operating system files and therefore cannot boot up.
This usually means that the hard drive in the computer is faulty.
You need to get a new hard drive and install Windows on the hard drive, together with the drivers for the computer's installed devices and programs to get a working computer.
Sep 06, 2009 | Dell OptiPlex GX520 PC Desktop
Dell optiplex gx280 won't boot up
you either have the boot priority in the bios off or you have improperly cabled your hard drive . perhaps you set it to boot to cd while installing the operating system and forgot to change the order back.
The floppy drive does not have to be present for the system to boot (if set to "not installed" in bios)
your boot devices are your cd/dvd rom and your harddrive.
Seeing as you've recently replaced the power supply , ime assuming you didnt dismantle the whole computer , just the power leads coming from the power supply, which means you only moved power , not data cables.
This would be the first thing to check -- power to the harddrive and cd rom, the 4 pin connector that sometimes connects to the motherboard and any data cables you might have bumped while changing the power cables. check these things and post here again.
Regards
Apr 01, 2009 | Dell OptiPlex GX280 PC Desktop
Can't boot my Dell Optiplex GX280 from the
Hi there
hey if you boot into bios and you need to make sure that the computer will recognize the hard drive and that the jumper that is on the hard drive is set as either master or slave depending on what you want than make sure that of the parameters are right and apply it. than restart the computer and than see if the cd will now boot and you should be able to continue from here ok
best regards mike
Mar 07, 2009 | Dell OptiPlex GX280 PC Desktop
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Miss match hd on a dell gx280
Hi, I have had lots of experience installing hard drives. You never get exactly 80gb when it is partioned. Some space is utilized for other things that cannot be used. So you aren't doing anything wrong. Just another way companies can make you think your getting more then you really are.
Dec 30, 2008 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
283 people viewed this question
Alun Cox
