Question about Goldstar MV-1526 Microwave Oven
Changed lightbulb I didn't read the warning about unplugging the microwave before I tried to change the lightbulb. When I unscrewed the lighbulb there was a *poof* and power was lost. The circuit breaker was tripped, so I turned it back on but the microwave still does not work. Any ideas what the problem might be and any feasible solution? Thanks!
  • dgalfano Apr 22, 2008
    Thanks for the quick reply! Well, I suppose it'd be worth a look assuming a replacement part would be reasonably priced and simple enough to replace. I'll look into it. Thanks again!
  • marie0503 Mar 14, 2009
    I need to change the internal light bulb on my goldstar microwave. I don't know where to open it to change it. I didn't see any answers on this blog. I didn't get the manual from previous owners. Help..
    Novelist:
  • 142 Answers
Simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Posted on Apr 22, 2008
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
Jul 16, 2012 | GE JES1142SJ Microwave Oven
How to replace light bulb in combination oven model acm1580ab
Cannot find your model number, please provide make and model.
Jul 23, 2008 | Amana Microwave Ovens
How to replace lightbulb inside microwave
Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
  • 2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
  • 3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
  • 4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
  • 5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
  • 6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
  • Oct 27, 2011 | GE JVM1860 Microwave Oven
    Jvm2070sk02 interior light does not come on can the bulb be changed?
    HELLO.
    When you open the door on your microwave, it sends an electrical current to the halogen lightbulb mounted inside the microwave. The signal turns on the light and illuminates the inside of the microwave.
    In addition, while cooking your food, the light illuminates so you can monitor the condition of your food while cooking. While the bulb generally lasts a long time, when it burns out, you must service your microwave.
    1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
    THANKS.
    willing to help on more question.
    Sep 06, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
    Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
    Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Lightbulb on ceiling of oven went out. How do I
    Hello :
    1:Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
    2:Unscrew all the screws around the casing by turning them counterclockwise.
    3:Remove the cover by lifting off.
    4:Locate the light bulb in the microwave. This will be located on either the right or left side.
    5:Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
    6: Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
    7: Replace the cover and screw back on. You are now done and may plug back in the microwave.
    Warning : Unplug the microwave before starting and wait 20 minutes for any residual electricity to be bled off from the capacitor.
    Things you will need : Phillips screwdriver
    good luck .
    please rate !
    Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    I need to replace the light bulb under my advantium 120 but my wife threw the lighbulb away I need to find out what size lightbulb I would need
    I would think that you can find that info either in the owners manual or right in the area where the light resides. Usually there is a sticker there with the info you need. Best wishes!
    Jul 29, 2009 | GE Advantium 120 Convection/Microwave Oven
    Light no longer working
    Most microwave ovens I have worked on the procedure is...
    UNPLUG the microwave.
    Remove the screws (along the bottom sides and the back of the oven) holding the the outer cover to the unit.
    Remove the outer cover and the lightbulb will be visible.
    Unscrew the bulb and head to the hardware store for a replacement.
    Reverse above procedures.
    Hope this helps.
    Apr 06, 2009 | Frigidaire FMV145K Microwave Oven
    Shorted it while changint lightbulb
    some microwaves have an internal fuse.
    Mar 23, 2009 | Maytag MMV5207AAS Microwave Oven
    How to change lightbulbs and how to get bottom off for cleaning
    Please unplug your oven before you remove or install bulbs!
    The bulbs are often tacked in place with contact cement or hot glue,and sometimes there may have been enough moisture to corrode and seize up.
    You could heat them up with a hair dryer to loosen the glue.
    That usually works.
    You can find helpful exploded view diagrams (and order parts if needed) by entering your full model number here.
    These views will help you see how the oven comes apart.
    Dec 22, 2008 | Microwave Ovens
    Goldstar MV-1526 Microwave Oven Logo
    261 people viewed this question
    Top Goldstar Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    SHARCNET-USA
    SHARCNET-USA
    Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
