Thanks mate, but can you explain - where do i start? Have i litrally gotta go in through the back and take the drum apart?
  • 487 Answers
Actually it is a little more complicated than that.
What you have to do is take top and back plates off.
First thing I would do is take the hose of the drum where the water pump (drain) is connected and see if you are lucky to see the wire through that hole. If not yes than you will have to dismantel the whole machine and take the outer drum apart.
Take motor out and than split the outer drum. ( they are locked together with bolts.) I know it seems like a lot of work but I have done it before and it is very possible to do it. Make sure that if you disconnect wires to mark where they go. You can even take pictures to help you assemble it again.
If you are not to keen about it you can always ask a local tech to do this. It will void your warranty if you do it your self.
Sorry that is is not an easy fix.
Posted on Apr 22, 2008
  • eric bosman
    eric bosman Apr 22, 2008
    this is my direction for front loader machines
I have a 1993 Dodge Dakota V8 4x4 with a 318. I dorped the truck into drive with the rpms at about 2500. A pop sound was made. Now it wont go into drive, 1st and 2ed. nothing even in 4L 4H. but will go...
First and foremost you must get any and all diagrams for the transmission so you know what you a taking apart. If this is your first time taking apart a transmission you will need to have as much knowledge about what you are about to undertake as you can get. Otherwise poor judgment will turn into a costly and time consuming event. After all that you can then start pulling things apart remembering that everything has to be kept clean. By all means do not use the old convertor and flush the oil cooler.
May 18, 2010 | 1993 Dodge Dakota
Drum separated from bulkhead!
There is a heavy cloth and rubber seal that is suppsed to be in the gap, it probably is worn off and fallen apart, they can be replaced by taking the dryer apart and removing the drum and puting on a a new seal
Oct 27, 2009 | Dryers
Dryer Drum bearing designs
these drum glides look cheap,but they last for a long time
Jul 26, 2009 | GE DVLR223 Dryers
Neptune MDE5500AY dryer drum weld came apart
Take the drum and part to a collision shop and have them mig weld it. Grind down the weld to make it smooth, and paint it. Reassemble.
Jun 13, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Elite Dryer Blower fan is loose
in the back opf your dryer the drum runs on 2 black rubber wheels when they are worn out it will giveyou that kind of noise replace them they cost about 8.00 each there is two of them you van see one from the bottom right side in the back of the drum if you remove the front lower panel thanks from gilles
Mar 15, 2009 | Kenmore Elite HE4 Electric Dryer
Large rubber door seal came apart
Yes it can be put back on without taking the drum apart. The larger end goes on the drum side. Fit larger end around drum lip make sure it seals all the way around, install spring around seal. Smaller end goes around door opening. Install seal around outter lip and install spring around seal.
Mar 05, 2009 | Kenmore 44102 Front Load Washer
pull the drum off and check the shoes if there is plenty of shoes grab hold of each shoe in one hand each and slowly pull them apart there is a ratchet mechanism that will operate and lock the shoes at the next level after each click put the drum back on and and see how it feals you want it to just be grabbing not to firm, if it is to firm get a screw driver between the ratchet mechanism and reset it back a click our two,
it is a little tricky the ffirst time so dont try it if you are in a rush to go some were
good luck mate
Dec 12, 2008 | 1994 Mazda 323
Took my Hotpoint VTD60 apart - cleaned out enough fluff from inside machine to stuff a horse... the Drum is now turning again - HOWEVER ... Could you explain how the Drum is meant to be secured at the...
You need a rear drum bearing kit. Go to any online parts source such as partsselect.com and do a search using your model # to see exact part and a reasonable price you look to spend on the part. I hope this helps you.
Sep 08, 2008 | Hotpoint Dryers
Power jack removal and installation
most laptops use a combination of screws and tab/slots clamping to keep the clam shell halves together. The tabs fit carefully into the mating slots, so it is up to you to find them. Carefully press in on the sides where the clam shell halves mate and find locations where it is more difficult to press inward. This area will be a place where to find a tab/slot mate.
Aug 18, 2007 | Fujitsu Siemens Lifebook N5010 Notebook
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
