Question about KitchenAid KSB5 Professional Stainless Steel Work Top Blender
Broke the coupling to our blender #KSB50B3 - KitchenAid KSB5 Professional Stainless Steel Work Top Blender
If you have a Kitchenaid Blender (model KSB50B3 or similar) and the rubber teeth on the coupling (that spikey rubber thing on top of the base) broke off (see picture), here is how you can fix it yourself! The Task: The coupling is screwed onto a vertical shaft like a button mushroom. The shaft is round with two flat sides. You need to find an U-shaped thing [such as a wrench] to secure the shaft and loosen the coupling by turning it CLOCKWISE. What you need: 1. New coupling: Part number KA-9704230. Shouldn't be more than $6. I got mine at www.goodmans.net. Their shipping fee is very decent and the service is also good. 2. An U-shaped object: Some had success with household forks. That didn't work for me. Most successes came from the use of ignition wrenches. There's only about 1/4 of an inch between the coupling and the base, and these very thin wrenches can get in there. You will need size 5/16 or 9/32. I got mine at Sears. They come in a set and are not cheap!! The steps: 1. Rip the rubber cover off the coupling. There's a metal disc inside. 2. Secure the shaft with the wrench. 3. Grab the metal disc with a plier and quickly **** it CLOCKWISE. This is to overcome the inertia. 4. If not loosened repeat steps 2~3. 5. Screw new coupling on COUNTER-CLOCKWISE. Now you are ready to make that smoothe or margarita or what have you again! Disclaimer: Kids, don't do this at home. I am not responsible for any explicit or implicit damages caused by you repairing your blender. Read manufacture's warranty policy before proceeding. Call their service center if you don't feel comfortable performing the aforementioned repair.
Posted on Sep 06, 2008
Looks like this "solution" was stolen from here:
http://seattlerainfestival.wordpress.com/2005/09/24/how-i-fixed-my-kitchenaid-blender-updated-2010/
Posted on Mar 23, 2011
Replacing washer underneath glass jug Waring pro blender PB20CXU
The bottom of the container should unscrew to expose the washer
Jun 27, 2013 | Waring Blenders
Need to replace coupler on KSB50B3 Kitchenaid Blender
http://www.appliancepartspros.com/search.aspx?model=ksb50b3
Nov 10, 2012 | KitchenAid Blenders
Ksb50b3 doesn't turn on hums
Does the blade turn by hand? Does the motor turn by hand? The answers to both those questions may point you in the right direction. If both turn freely I would suspect you need a new motor.
Jun 07, 2012 | KitchenAid KSB560 5 Speed Blender
Part "i" , the plastic(nylon) tooth part on my Braun PowerMax Blender, type 4184, broke and I need to find a replacement part. The Braun Service website was useless. Can you help? ...
www.smallappliance.com. you can order a new blender blade which has the white nylon teeth or you can order the coupling which is the black teeth that the jar sits on. NOTE: the black one is easy to replace, but getting the screws out of the base is the hard part.
Jul 02, 2010 | Braun MX 2050 PowerMax Work Top Blender
Broken blender coupling
Try going to MarBeck.com they are a great source for small appliace parts.
http://www.marbeck.com
Dec 15, 2008 | Black & Decker BL600 ProBlend Work Top...
The coupling of my kitchen Aid blender is broke could tell me how to change it
Visit MENDINGSHED.COM.
On the left, click KITCHENAID. On the next page, click KITCHENAID BLENDER PARTS. On the next page, you will see a listing for a drive coupling. You want to choose on the left, which is retailing for $5.95.
You may order the part if you need it. If not, click onto the parts order page and scroll down. There will be a two-step instructional guide on how to properly replace the coupler.
Sep 14, 2008 | KitchenAid KSB5 Professional Stainless...
Top part of base broke off
This just happened to me too, and I think I just fixed it.  First you have to get a replacement part called the "blender coupling" (I got mine online from Goodmans for $3.99).  I also replaced the square drive and slinger (two parts come together for $2.99)-that's the little part that sticks up and attaches to the pitcher.
Unscrew the bottom four screws of the base where the rubber feet are.  Remove the rubber skirt to reveal four screws that hold the motor in.  They are way in there so you'll need a long screw driver.  Remove the motor and unscrew the old coupling.  Mine had not been replaced since my grandmother bought this blender who knows when, so the coupling was really stuck.  I did not have a tool narrow enough to get a good grip to apply enough torque to remove the coupling so I had to try a few other tricks.  If your blender is the same, remove the bottom nut, fan blade and two washers.  This gave enough of a rod to grip to get the old coupling off.  (I also had to use some WD40, and heat and cool the coupling a few times to break the old seal).
Good luck!  Hope that helps!
Jan 09, 2008 | Oster 465 Work Top Blender
KitchenAid KSB5 Professional Stainless Steel Work Top Blender Logo
2,309 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
