Question about LG Flatron L1750S 17" LCD Monitor
I have a flatron l1750s monitor when I boot up the screen will flick to loading then it dissappears to a black screen But if I turn the monitor off then back on it shows my desktop for a sec and screen goes black is there a way I can fix this problem ? Ifso, what is needed to fix it?? any help would be greatly appreciated. Thanks Krshinkle2000
    Guru:
  • 195 Answers
Log on to forums.techpowerup.com for a solution...
Posted on Jul 20, 2010
LG Flatron screen out the writing power save mode and then only a black screen please give solution thankz
I have a power save problem, a capacitor causes it where can I found the capacitor on the power circuit?
Jan 20, 2011 | LG Flatron L1750S 17" LCD Monitor
My lg flatron l1753s shows some visual disturbnce like somthing flowing and in few moments shows completely black screen after that normal so......plz tell me what to do to fix it?
It could be the domestic maintenance problem keep your monitor away from moisture and other physical damage it will make your monitor perfect as new working...
Dec 09, 2010 | LG Flatron L1750S 17" LCD Monitor
Flatron L1750S (Silver, Black) 17" LCD Monitor: Out Of Range - what does that mean...
Your PC video resolution is too high for this monitor to display, you need to set your PC video reslotion to the native resolution of this monitor, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | LG Flatron L1750S 17" LCD Monitor
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L177WSB-how would I use my newly purchased unit after switching it on, LG logo appears followed by the Power Saving Mode it all goes black on the screen.
Hi, the Power Saving Mode, turns the screen off to conserve energy. On the remote, press Menu, and scan to Power Saving Mode. You can change the amount of time, when the Screen turn-off, the TV shut-off etc. You can set the time to (5 min) to, (never, turn-off). This should help with your problem. Thanks paul7of9
Jan 14, 2010 | LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1750S when powered on blinks and then goes out. I have switched over to two other machines (pc's) and the problem follows. Please help me I can afford to buy another monitor right now....
melrosebanjo, Your monitor will need to have some work done on it's "switch-mode-power-supply" and /or "INVERTER" circuit. After you view some vids at YOUTUBE that deal with replacing bad electrolytic filter capacitors and detecting poor quality intermittant solder joints. Search for vids of "LCD monitor repair" "LCD monitor disassembly" !! Learn what are the major causes of LCD BLACK screen problems. Learn the difference between BLACK AND BLANK screens. Read some of my other posts in my profile. then repost with additional comment here on fixya. also visit www.ccl-la.com/badcaps.htm. and www.lcdparts.com
www.badcaps.net FYI Good luck 12fixlouie
Dec 12, 2009 | LG Flatron L1750S 17" LCD Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor hit with a Headphone
The black spot can stop or keep spreading, but it will never disappear or reduce in size. This is caused from a leak of liquid between layers inside the lcd panel.
Nothing to do apart changing lcd panel. Bring monitor to nearest service and check if it is worth being repaired (changing screen panel).
regards
Mar 04, 2008 | LG Flatron L1750S 17" LCD Monitor
L1750s 17"
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
http://www.lgservice.com/
Dec 31, 2007 | LG Flatron L1750S 17" LCD Monitor
Black line across my screen
hope your flatron is under wtty, get it checked before it is too late. It is a hardware problem which you cannot fix by yourselves.
Sep 29, 2007 | LG Flatron L1750S 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
347 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
