Question about Apex Digital GT2715DV 27 in. TV/DVD Combo
A straight line across the screen.
My t.v. has a straight line through the center of the screen.Everything else works fine. CAN THIS BE HELPED!!!
  • 758 Answers
The problem may have been caused by the Vertical Filter Capacitors located in the immediate area of the deflection chip. If this is the case, and the chip you is bad. You need to check for a shorted capacitor before rechanging the chip again.". Please contact APEX for more info....The number is (800) 880-1227
I hope that helps
Please rate accordingly
Thank you
Posted on Apr 22, 2008
    Genius:
  • 1,447 Answers
Are you watching a movie from a dvd? what type of cable are you using to connect the source(Cable, DVD)?
    President:
  • 1,944 Answers
Did you try disconnecting the TV from the power for a few hours to reset?
  • 2,322 Answers
It looks like an IC has failed on your TV.
The IC is the vertical amplifier and needs to be replace to restore the functionality of your TV.
  • Jaime Hernandez Apr 22, 2008
    I would suggest to take the TV to a service center as this repair might not be a DIY. A fair price to pay for the repair should be about 1/3 of the price of the TV.
Toshiba 42H82 the screen will go black after 5 minutes, sometimes it comes back on after a minute, but most of the time I have to turn it off for about 10-20 minutes. Some days it works fine, others it...
Hi.
It is probably a defective ballast board or a faulty PSU. The ballast is the high voltage power board connected to the lamp.The PSU is the board that supplies power in different voltages to the other internal parts. One of the DC lines from PSU goes straight to the ballast. The repair is done testing the voltage from PSU to ballast. The job must be done by a technician.
Dec 15, 2011 | Toshiba 42H82 42" Rear Projection...
THe tv is showing just a line straight across the tv
Vertical Ic collapsed need to be replaced
May 27, 2010 | Sansui DTV2760 27" TV
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Sep 16, 2009 | Hitachi 36UX01S 36" TV
Red lines across the screen. Small area works fine
You are going to need a new panel (screen).
Wish I could be of more help to you but there is no help for this one.
Aug 09, 2009 | Philips Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Vertical Line in center of screen
never heard of so called card myself but ,is the line your talking about from top to bottom or from side to side in the middle?straight across middle is called horizional which means vertical problem so you have either bad capacitors 35uf 100v ,1uf 50v, or bad vertical output ic.
Dec 26, 2007 | Curtis-Mathis CM32010 TV
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Apex Digital GT2715DV 27 in. TV/DVD Combo Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
