Question about Acer 22" X223w LCD Monitor
Screen is too light, how do I darken - Acer 22" X223w LCD Monitor
    Brigadier General:
  • 10,406 Answers
Press the 'OSD' (On Screen Display) button on the front/bottom of the LCD, to show a bunch of menu items. Choose "brightness", and adjust it to a darker value.
Posted on Jul 20, 2010
Tv screen darkens at night
The set likely has a light sensor on the front of it to change brightness with light changes in the room, if not in the menu to switch on or off contact LG to see with the model number what can be done.
I have seen some where the sensor had to be disconnected inside to correct this issue. Sets as far back as 50 years ago had this issue.
Oct 22, 2012 | LG Televison & Video
LOOKING FOR A REPLACEMENT SCREEN
Darken the screen and either move the lid forward or backwards. Laptops have Liquid Crystal Screens and moving the lid backwards or forward will give the screen a different look.
If you need to adjust the brightness of the screen it is controlled by keys on your laptop. Most times to darken the screen you will have to hit the FN, CTRL or ALT key and hold it down while you hit the key that corresponds to the screen darken key. On some computers (even on my laptop) it will be the down arrow key, so i would press FN+the down arrow key. Remember to hold the first key down while you hit the next key. The icon used for most times to denote the brightness or darkness looks like a circular sun or a washer that goes on screws.
Mar 22, 2012 | Computers & Internet
Why is my picture darker than normal
It may be the backlighting has been readjusted by someone other yourself. Whenever you go on battery, I'm sure you've seen the screen darken a bit. This is the backlighting being turned down to save battery life. There is usually a blue function "fn" key that allows the user to brighten or darken the display. Look at the blue icons in the F1-F12 keys. The one to brighten the display looks light a sun and the one to darken the display looks a full moon eclipsed. Press and hold the fn key and tap the desired function key to brighten or darken the display.
Jan 13, 2012 | Toshiba Computers & Internet
My calculator started malfuctioning and it would only show little lines instead of numbers so i took the batteries out tried new ones but it wont even turn on now
After you replace batteries, the screen contrast may become too light or to dark. In your case, I suspect it lightened too much.
To darken screen
Press [2nd] key and release it.
Press and HOLD the [UpArrow]
Keep pressing the Arrow key until screen darkens to your liking.
If that does not solve your problem search this website: I have answered countless number of questions on the same subject.
Feb 03, 2010 | Texas Instruments TI-83 Plus Calculator
My kid's calculator is not working; replaced new batteries including the lithium battery. yet, the calculator is not turning on.
After a battery replacement the screen contrast may become too dark or too light. I suspect that in your case the screen is too light. To darken it
Press and HOLD [UpArrow] until screen darkens enough.
Jan 30, 2010 | Texas Instruments TI-84 Plus Silver...
The screen is black when I turn it on. I've replaced the batteries and no change. I try to change the contrast and nothing happens. It is a couple years old, but I should still work.
Check that the terminals in the battery compartment are clean and shiny. Remove any powder left after battery leakage. Insert fresh batteries in calculator. Make sure you respect the polarity diagram. +-+- (Many malfunctions come from incorrectly placed batteries).
To adjust the screen: Darken or lighten display
To darken screen
Press and hold [UpArrow] until screen is dark enough.
To lighten screen
Press and hold [DownArrow] until screen is light enough.
Hope it helps.
Dec 03, 2009 | Texas Instruments TI-86 Calculator
I have a blank screen. The unit lights up but i can't input data.
It is possible that the screen is too light to see anything. If that is the case you can try to darken the screen a bit to verify if it works.
To do so:
Press and hold the UP arrow to darken the screen. Keep pressing until it is dark enough.
If that does not work, you may have to follow the link to the TI FAQ and Knowledge Base to an article that addesses the question of a graphing calculator not turning on.
Hope it helps.
Nov 10, 2009 | Texas Instruments TI-83 Plus Calculator
After 5 minutes monitor screen dims--can faintly see the windows screen and then it flickers out and there is nothing. Any ideas?
the monitor may be going into power save mode which it should come out of when you press a key or move the mouse but it sounds like you have tube inverter issues. Your screen has light tubes behind it to illuminate the screen, if the tubes or the inverter develop a fault, then a very dark screen can result as the tubes are turned off. There may also be an ambient light sensor which will darken the screen in low ambient light. If the sensor is faulty, darkened screens will result. If the inverter is failing, you may be able to replace it, contact viewsonic. if the tubes are failing, replace the panel or the entire monitor. If the ambient light sensor is faulty, replace the panel or entire monitor as the sensor is part of the display panel.
Nov 02, 2009 | ViewSonic VG900b 19" LCD Monitor
Plzzzz help!!!!!!!!!!!
Check that the batteries are correctly inserted.
The screen may be too light to see anything.
To darken it
Press and HOLD [UpArrow] till it darkens enough.
Hope it helps.
Oct 27, 2009 | Texas Instruments TI-83 Plus Calculator
My TI 84's screen went black.
One possible solution is to dim the screen contrast. To do this, turn the calculator on press the 2nd key, then the up arrow. If contrast has been darkened, this should work. To darken the screen if you get it too light, you do the same, but use the down arrow. Hope this helps.
Oct 01, 2009 | Texas Instruments TI-84 Plus Silver...
Acer 22" X223w LCD Monitor Logo
362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
