Question about Casio FX-9750GPlus Calculator
I need an inverse log button on the casio calculator 9750GII.... does it have one??? I know how to do log, but can't find the inverse.
  • Casio Master
  • 7,993 Answers
The log base 10 function has an inverse: It is the 10 ^x function. It shares the same physical key with the decimal log. Use [SHIFT][LOG].
The natural log (LN) has an inverse alos and that it the exponentila function e^x. It shares the same physical key with it.
Posted on Jul 20, 2010
Testimonial: "I can't thank you enough!!!!!!!!!!!!!!!!!"
How come when i try to do inverse trig function on my fx-9750 gii calculator it says Ma error?
Just wondering if the other functions are working.
The manual references setting up angle unit and setting up the "comp for mode" in the setup.
The keys you should be pressing to do this calculation are on page 51 (2-31) of the attached manual.
http://support.casio.com/manualfile.php?rgn=5&cid=004002013
Good luck. If unsuccessful, please repost.
Paul
Nov 03, 2016 | Casio FX-9750GII Graphing Calculator
Casio fx-9750GII is giving the wrong answer, is it broken?
Check the calculator with a simple 2X2 matrix that you can invert by hand easily and see if it gives you the wrong inverse for it. It is also possible that YOU made the mistake.
Jan 03, 2016 | Casio FX-9750GII Graphing Calculator
How to calculate inv logs on casio fx-82 au plus?
The inverse of log functions are power functions.
Inv of ln is exponential (e^x)
Inv of log in base 10 is 10^(x)
A function and its inverse usually share the same physical key. One function is accessed directly, the other by using the SHIFT or 2ndF key.
Aug 18, 2014 | Casio Office Equipment & Supplies
How do I calculate inverse logs on casio fx-82au plus?
Where is the inverse button on the casio fx-82ES
For the reciprocal of a number, enter the number then press the key marked with an x^-1. You might have to use the SHIFT key first. For inverse of trigonometric functions use the SHIFT key followed by the function name. The inverse of LN is e^x. The inverse of log is 10^x. To calculate the inverse of a matrix, enter the name of the (already created) square matrix then press x^-1.
Jan 09, 2012 | Casio FX-115ES Scientific Calculator
How can i calculate log inverse with my fx-991ES plus
By 'log inverse', you presumably mean the inverse of the logarithm function. There are two logarithm functions on most scientific calculators. Firstly [ln], or natural logarithms, to the base e, where the inverse is e^x. Secondly [log], or logarithms to the base 10, where the inverse is 10^x.
Example 1 : ln(2) = 0.69314718 so e^0.69314718 = 2
Example 2: log(2) = 0.301029995 so 10^0.30102995 = 2
Oct 02, 2011 | Casio FX-115ES Scientific Calculator
How to take anti log in casio fx 991 ms and give example?
Depending on the actual log function you are talking about, the inverse function (what you call the anti log) can be one of several things.
The inverse of the natural log (LN) is the exponential function e^x.
If y= ln(x) then x=e^y
On a calculator functions that are inverse of one another share the same physical key. If one function is marked on a key, the inverse function is usually the SHIFTED (or 2nd) key
The inverse of the common (decimal logarithm) is the power function with 10 as base.
Example: if y= log(x) then x=10^y
For an arbitrary base (must be positive) if y= log_b(x) then x=b^y.
Note: I do not think that the FX-300ms can perform log calculations in bases other than e (natural log) or 10 (common decimal log).
Aug 13, 2011 | Casio FX-300MS Calculator
Negative log
Actually, it's the inverse of log, or 10^x, to do so, simpily press [2nd] [LOG].
May 07, 2009 | Casio FX-260 Calculator
In this calculator how to calculate log inverse of
My way is really slow b/c I don't know the right way, but I always clear my memory (SHIFT, CLR on the 9 button), then type it in as an equation, for example: log(X)=-15.3, then press SHIFT, and SOLVE (on the calc button), then press =. It freezes up the calculator for several seconds though =/
May 02, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-9750GPlus Calculator Logo
1,867 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
