Question about Apple iPod nano 3rd Generation
My ipod still.
I've found it in adminstrative tools, but i don't see device manager.
  • 85 Answers
I found it ther on Vista and another way to find it is to just do a search for it and include hidden and system files and all of the other stuff and you will find it and it will be in categories and click on USB and click on output power and make it higher than what it is now.
Posted on Apr 22, 2008
How can I unlock my iPod its a lost and found from work and on the screen it's say activate iPod but the owner lock it its says sign in with the Apple ID that was used to set up this iPod,, is
If is ordinary your ipod and you have proof that is yours (like a receipt) you can contact the apple support and will help you with removing the apple id. If is not yours or can not prove you are the original owner then eitehr contact the person that has the apple id r are services to remove that but cost around 130-150$
Oct 23, 2014 | Apple iPod Touch iTouch 8GB WiFi MP3 Video...
My ipod classic says it has 1840 photos and I can see them on the device but I can't get them off the device
Hold down theShift and Control buttons when you plug in the iPod / iPhone to prevent it from syncing, then from the iTunes menu, click on the device under the left panel. Make sure you've got "manually manage music and videos" checked as well as "enable disk use," which will come in handy later as it lets the device appear in Windows Explorer as an external drive.
As far as images go, for all models of iPod, they're found under the decidedly more public folder Photos, so once you've enabled disk usage, it's pretty easy to find. However, if you haven't checked "include full-resolution photos" under your iPod's Photos tab in iTunes, all you'll see here is a Thumbs folder, which contains the pics in the .ithmb format specifically tailored for the iPod screen. If you're in desperate need of these low-res copies, you can find conversion tools online pretty easiliy.
Oct 01, 2013 | USASPEC PA12-BMW iPod Interface with Text...
Volume limit password reset on ipod nano
Hi
How to Unlock iPod Volume Limit
Your iPod volume can be limited, and in many instances, a PIN number will be necessary to remove the limit. If you've forgotten or misplaced your PIN, you can still unlock your iPod volume limit using your computer.
1 Connect your iPod to your PC. Make sure your hidden folders are visible.
2 Navigate to the "iPod_control" folder. This will be a hidden folder. Once you've found the "iPod_Control" folder, navigate to the "Device" folder.
3 Locate the file named "_volumelocked" in the "Device" folder. Delete this file.
4 Eject and restart your iPod.
5 Navigate to "Settings" on your iPod. Select "Volume Limit." You'll be able to reset your volume limit with a PIN or password.
Tips & Warnings
Do not listen to your iPod at high levels for long periods of time; doing so can damage your hearing.
Nov 23, 2011 | Apple iPod nano
How to delete photos in itouch photo library in my 4th generation itouch?
you have to hook it up to a computer and depending on whether you've been using iTunes or windows explorer to manage the ipod will determine how you delete it. in itunes you just open the ipod menu on the navigation bar on the left side of the screen, open the photos tab, and delete the ones you don't want. Alternatively in windows you can open the device in "my computer" go to DCIM and delete the photos there too.
May 03, 2011 | Apple Audio Players & Recorders
My ipod is not connecting to my system
Hi,you can use your iPod to a Windows and Mac, in conjunction with a USB port. Any iPod with dock connector, which has one, can be plugged into a USB 2.0 port. For a system to transmit data and provide access to information on your iPod, it is important that the system initially, we should recognize as a real device. But if your system is not, then the probability that the internal structure of the iPod is corrupted and you need to reformat. After formatting, if you have deleted the backup to restore the data youYou must use iPod Data Recovery Tools.
For example, if you connect your iPod to your Windows-based system with a USB port, you can the following error message:
"USB Device Not Recognized
One of the USB devices connected to the computer has a problem, and Windows does not recognize. For assistance in solving this problem, see this message. "
CAUSE
This error can result from various reasons, some of which are listed hereinafter
Defective USB Mass Storage Device Driver
High-speed USB ports are enabled
File infcache Problematic
Damaged the internal structure of the iPod
Solution
You should try these methods to solve the existing problems and to recognize that your iPod in Windows:
Unplug your iPod and disconnect
Disconnect iPod and connect to the system is rebooted
Put your iPod
Replace or upgrade the USB mass storage Device Drivers
Tip: Disable high-speed USB. To do this, right click on My Computer and click on "Manage" from the menu. Then click on "Device Manager" and double-click the Universal Serial Bus controllers. You can then access all the USB items that are identified as "best disabled ',' high-speed" or "USB 2.0".
Delete the file asy
If the problem persists, please format your iPod and lost data from backup. But sometimes, when the backup is not complete and updated is valid, backup should be restored. To solve these problems, should be used iPod recovery tools. IPod Data Recovery Tools are commercial tools with powerful recovery techniques designed to take to protect data, seemingly inaccessible.
Stellar Phoenix iPod Recovery is a fully equipped tool for data recovery lost data from iPod shuffle, iPod nano, iPod mini and iPod Classic. This is a read only tool that has lost everything, music,Videos, documents, images, podcasts, audiobooks and other content from iPod. This iPod recovery tools for Mac and Windows operating systems.
Have a nice day...
Mar 02, 2011 | Creative Labs ZEN V Plus MP3 Player
Computer cannot recognize the drive now, after months of use.
Check the Adminstrative Tools status.If it says unallocated,it needs to be either reformatted or recovered.
Sep 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I bought a second hand nano not working
Locate the iPod in Device Manager
  1. Connect iPod to the computer.
  2. Quit iTunes if it launches.
  3. On the Start menu, click Control Panel.
  4. In Control Panel, open Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  5. Double click the Computer Management shortcut.
  6. In the left column, click on Device Manager.
  7. In the right column, click the plus (+) icon next to Universal Serial Bus controllers to expand this selection. ts1538_1.jpg
  8. Locate the iPod in this list. In some cases one of the entries will have "iPod" in its name. If no such entries are present, the iPod is most likely represented by "USB Mass Storage Device." ts1538_2.jpg ts1538_3.jpg
Note: A red "X" appearing next to the iPod's entry in Device Manager indicates this device is disabled. To enable this device, right-click its entry in Device Manager and choose Enable from the shortcut menu.
ts1538_4.jpg Update the USB driver
  1. Right-click the iPod's entry in Device Manager and choose Update Driver from the shortcut menu.
  2. In the Hardware Update Wizard that appears, select "Yes, this time only" to allow Windows to connect to the Windows Update Website. Click Next. ts1538_5.jpg
  3. Select "Install the software automatically (Recommended)" and click Next. Windows searches for updated drivers and installs any it finds. If Windows is unable to find updated drivers on its own, continue with step #4.
  4. Click Back.
  5. Select "Install from a list or specific location (Advanced)" and click Next.
  6. Select "Search for the best driver in these locations."
  7. Select "Include this location in the search" and type the following in the field below: C:\Windows\INF ts1538_6.jpg
  8. Click Next. Windows searches this location for drivers and installs any it finds. If Windows is unable to find updated drivers on its own, you must reinstall the USB drivers as shown below.
Note: During installation, if a message appears stating that the software you are installing "has not passed Windows Logo testing" click Continue Anyway to continue installing the drivers.
Reinstall USB driver
  1. Right-click the iPod's entry in Device Manager and choose Uninstall from the shortcut menu. ts1538_7.jpg
  2. In the resulting dialog box, click OK.
  3. In the Device Manager window, right-click Universal Serial Bus controllers and choose Scan for hardware changes from the shortcut menu.
ts1538_8.jpg Windows automatically reinstalls the necessary USB drivers and attempt to remount the iPod.
Try these and reply me about the current status of the ipod..
Feb 11, 2009 | Apple iPod nano 3rd Generation
Acer extensa 4210
reinstall the drivers, or go to your adminstrative tools in the control pannel and then computer managment, and then services and applications, inside you will find a list on services on your computer, find you cam and check its settings, you can also go to control pannel, sysytem, hardware and find the cam click on it, it should tell you if it is running correctly, you can also reinstall, the drivers from there
Nov 04, 2007 | Acer Extensa 367D Notebook
Apple iPod nano 3rd Generation Logo
15 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
