Question about Garden
I have a Campbell Hausfeld 2200 psi power washer that is roughly 10 years old. It has a gas powered 6 hp Briggs & Straton motor. Unfortunately the washer has been dormant and was stored outdoors in Wisconsin for the past several years. i've dismantled some of the exterior parts to clean out the spider webs and get at the motor. I pulled the spark plug and found that the piston still has compression and that the valves are operating. now then I've lost the owners manual and simply need to know if there is a fuel filter and where it might be; what type of oil I need to use; and lastly if I need to replace the throttle spring that has become fairly rusty and somewhat lifeless?
  • 4234 Answers
SOURCE: starts and idles and runs half speed ok -- dies off on full throt
Since you don't indicate the make and model, I can't give you specifics, but when I had this problem it turned out to be a dirty carb. This can cause uneven fuel flow and loss of power. At full throttle, you may not be getting sufficient fuel to work properly. Try cleaning the carb a nd update this with the results.
Dan
Posted on Jan 30, 2010
SOURCE: I want a phone number
I agree. At least give us a phone number that is disconnected so we know you care.
Anyway, for a few bucks more, fixya has experts who get paid to hear your pain. Pay them to help you get the job done. See if fixya works for you.
If these companies offered phone service, they'd be covered up with calls, and the folks answering the phones would have to be as expert as you are at your job ... and they'd have to know every single model and part number and assembly feature. That would be hard to find professional phone talkers. But fixya is trying to fill the gap.
I can see the companies are changing. More of them are posting manuals. And posting their old manuals too. But the manuals do NOT have the level of detail that professionals like you need. They need to post more detail. But I think they have short manuals to save paper when they mail out a product .... on-line they could have longer manuals.
A lot of people are saying the same thing you are. Things change when we complain.
Bump up a dollar and try the fixya experts, and then speak up if it doesn't work.
Posted on Oct 17, 2010
puertobori
  • 7733 Answers
SOURCE: I have a 2000 PSI
Go and eReplacementParts.com : Power Tool Parts and Tool Repair
Posted on Nov 10, 2010
skookumfab
  • 93 Answers
SOURCE: I recently inherited a Campbell
http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Posted on Dec 08, 2010
  • 492 Answers
SOURCE: i have cleaned the carby,
sounds like it threw a rod or something take the spark plug out hold ur finger over the hole and crank it and see if it blows ur finger off the hole if it dont then its either broke a ring or threw a rod (probably the clunking noise u hear)
Posted on Jan 23, 2011
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
May 04, 2015 | Campbell Hausfeld Garden
I need to separate the pump from the 5.5hp gas engine
usually held in place by 4 alen key or hex bolts. sometimes very difficult toslide appart.
be sure to meassure shaft size as they are usually different size on each motor size graduation.
Aug 22, 2013 | Campbell Hausfeld Pressure Washer Gun -...
What is average going price for a new or used wobble pump for a Campbell Hausfeld PW2200V1LE. My 6.0 Briggs & Straton engine is in very good condition Reason I ask is a brand new pressure washer in my...
keep the briggs if your just gonna use it for yourself get the sjv axial pump 239.00 put it on your briggs.many retail stores use s disposable pump no sightglass or drainplug sjv has forged brass head no pot metal.
Jul 30, 2013 | Campbell Hausfeld Garden
Need the connection for the wand hose to the pump for Blue Max Gasoline High Presssure Washer stock No: PW2200/03435
Your pressure washer is sold under various brand names, however I believe that it is made by campbell hausfeld. Parts are here:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/campbell-hausfeld/PW2200
Take a close look at the pump diagram to make sure it looks like yours. Good luck
Nov 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
I have a Blue Max high presure washer, 2200 psi.
Hi Greg. Walk into your nearest Lawn Mower parts supply with your engine model number (usually on the recoil) and they will have the replacement part or repair your old one. It is less expesive to have the old one repaired unless the support struts have broken. 2200 PSI should have a Honda GX160.
engine:
Here is another source....
http://www.northerntool.com/shop/tools/product_200327175_200327175
They can range from $32.00 to $68.00 depending on source.
Honda PN is: 28400-ZH8-013ZA (do net search this number) Or call your local Lawn Mower repair Supply with the number.
If you have a Briggs & Stratton engine I will need the ENGINE model number off of the air shroud just above the spark plug.
Thanks for using FixYa.
Kelly
Apr 05, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Need new pressure regulator for Campbell Hausfeld
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
2200 psi husky briggs and stratton pressure washer used 2 years never used soap dispenser trying now is not drawing soap no longer have manual to see how to connect adjust can you help?
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Jan 16, 2010 | Briggs & Stratton Gas Pressure Washer...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
