Question about Vivitar ViviCam 3785 Digital Camera
Formatting memory card
Hi, i have a nikon coolpix L4 and i put my memory card in and it said that the card needed to be formatted. after formatting my card it said that "card could not be used" what should i do?
-card is not new
Deanna
    Genius:
  • 1,234 Answers
Hello , Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    Hello there, I have a Nikon Coolpix L4, and I'm trying to use a 4GB memory card in it that was most recently used in a Canon digital camera. I'm getting the error that "this card cannot be...
    Sorry to tell you, but your older camera will not work with 4GB or higher SDHC cards. Your camera was designed before SDHC format came out. You'll need to use 2GB or less standard SD cards. These are relatively inexpensive these days, and are easily found on Amazon, just in case your local store no longer carries them. For others reading, there are several other possible causes for memory card problems, with troubleshooting steps that may be viewed here.
    Jul 09, 2011 | Nikon COOLPIX L4 Digital Camera
    Memory card failure in camera
    Your memory card needs a permanent home. Trading it between cameras is corrupting it. If there are pics on it, use a card reader to download them. Then choose a camera and format the card in that camera.
    Feb 06, 2010 | Nikon COOLPIX L4 Digital Camera
    Everytime i turn the camera on it says that "this card cannot be read"
    Hi, the data on the card is corrupted and as a result is not reading it, you will need to format the memory card, if you cannot format it through the camera i suggest formatting it through the computer.
    Hope this helps
    Muzzi_123
    Nov 11, 2009 | Nikon COOLPIX L4 Digital Camera
    Nikon Camera does not accept any memory card
    Try formatting the card in the camera, not the computer.
    Apr 14, 2009 | Nikon COOLPIX L4 Digital Camera
    Deleting Mass Pictures
    You can and should delete your images while the memory card is in your camera. In your manual or on the menu of the camera find the "Format" procedure and format the memory card.
    Always do this with the camera. It does not work well formating the memory card with a computer.
    Mar 20, 2009 | Nikon COOLPIX L4 Digital Camera
    Nikon Coolpix L4 Memory card problem
    Back up all the pictures on the card and then format the card.. Everything will be back to normal.
    Note: While formatting select FAT32 file system as it is more reliable..
    Jun 18, 2008 | Nikon COOLPIX L4 Digital Camera
    F0rmatting memory card
    make sure you format is from the camera since if you format it from the computer it might format it as a different file system which is not compatible with the camera.
    Apr 22, 2008 | Vivitar ViviCam 3785 Digital Camera
    Vivitar ViviCam 3785 Digital Camera Logo
    37 people viewed this question
    Top Vivitar Cameras Experts
    Tony
    Are you a Vivitar Camera Expert? Answer questions, earn points and help others
