Question about Sonic Boom Alarm Clock - Options - With Super Shaker Bed Vibrator
Looking for key override on diplomat safe 125 en
My Safemark Systems electronic safe won't open. I have the code but my batteries are completely drained. How do I get in safe?
4 0 Electronic Safe
use your cobra key or buy this Emergency Handheld Override,that goes to it,or replace the batteries.
Emergency Handheld Override EHO
Safemark Systems
2101 Park Center Drive
Suite 125
Orlando, Florida 32835
USA
1-800-255-8818 USA
1-407-299-0044 International
1-407-299-7650 Fax
1-800-299-4288 Tech Support
May 01, 2015 | Locks & Locksmithing
Can't open safe Model: 119TR5EN Serial: E10034583 Made in Korea Diplomat safe No key, forgot combination How do I get it reopened
Take it to a locksmith, if it can be open they will let you know ? I have taken many locks and safes to my local locksmith to have opened or new keys made.... hope this helps?
Feb 23, 2015 | Home Security
No override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Nov 15, 2012 | Safe International Sentrysafe X055...
My husband has passed and all of our insurance, house deeds and other important papers r in the safe. the x105. He handled things like that. but i must get to the life ins papers. I dont know where the key...
There is no override code. But maybe a override key the normal key is to open the bolt after the correct code is entered.
Cracked or drilled.
Call a locksmith to help.
Don't fall for the biggest add in the phone book a good locksmith could never afford a full page add and offer a good price.
Jul 18, 2010 | Sentry Large Security Safe - Safe - X105
I lost my sentry safe code! what can i do to program the safe! can i do it without the code? please help! thanks
Depending on model, some safes have a key override that can be used to open the safe. Most models do not. Without a key override, probably the only thing you can do is to contact a lock smith, otherwise, start checking each possible code combination until you find the correct code.
If there are valuables in the safe, then take it to a locksmith. Otherwise, it might be cheaper to get another safe.
Jul 14, 2010 | Sentry Fireproof Safe
Digital Electronic Security Safe S2120.
You will probably have to call a locksmith who specializes in digital safes, or you can contact hardline and give them the serial no. of the save and proof of purchase to get the code or key. You will probably need proof of purchase for the locksmith to.
Sep 18, 2009 | Kitchen Appliances - Others
I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Apr 27, 2009 | Safe International Digital Electronic Safe...
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Sonic Boom Alarm Clock - Options - With Super Shaker Bed Vibrator Logo
268 people viewed this question
Top Sonic Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Martin Murray
 Grubhead
Grubhead
Are you a Sonic Audio Player and Recorder Expert? Answer questions, earn points and help others
