Question about LG DN191H DVD Player
NO DISK MY CD PLAYER CANNOT READ THE DISK.....ALWAYS NO DISK
Unit may have defective optical pick-up. Or make sure disk is not in up side down. Or it may have processor lock up -- unplug for 24 hours
Posted on Apr 22, 2008
Dvd will not play - it always says check disc
the lens unable to read the disk,clean the disc with a soft cloth dipped in a cd cleaner. if it still cant read try to clean the lens as it could be covered by a film of dust.
Sep 24, 2011 | Sony DVP-FX810 Portable DVD Player
My fukuda dvd player won't play any dvd or cd.It always show the "no disk " error even if there is already a cd/dvd inside.Already remove the top cover and saw that the disc is spinning but will...
Either the spindle motor is not reaching the required speed to read the table of contents, the traverse motor is in the wrong place and won't allow the disc to be read or the laser is faulty.
It could be any combination of the above. Time for a new player?
Feb 04, 2011 | Televison & Video
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Will not read blank disks
IT could be youre using a different type of CD-R , MAKE sure CD PLAYER matches with the correct CD-R format eg. CD-R- CD-R+ , CD-RW , etc. thanks AJ
Nov 19, 2009 | Office Equipment & Supplies
Dvd player always says no disc . will not load
That happens because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only few CD, DVD. After more prolonged usage , often the unit will start losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the player, and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Aug 28, 2009 | Philips DVP3962 DVD Player
Cd/dvd cannot be read by the player
EITHER CLEAN or replace THE OPTICAL LENS , try first to clean it directly with a DRY Q-tip ,and test player again. if it doesnt read , then replace the optical lens, hope this helps , AJ
May 19, 2009 | Televison & Video
Player shows '' No Disc'' even when inserted with a disk
When player says no disk, even if the disk inside, and you hear a whirring and clicking noise when you insert a disk, that means that the CD lens is dirty or defective, and the CD drive cannot read the initial CD track, and returns no disk.
Try first using a CD cleaner disk, if that does not work, then you will need to take the apart the unit to clean lens with isopropyil alcohol and cotton sticks.
See also the following websites on how to clean the lens, use a cleaner disk first:
Gizmo Highway DIY - Clean your CD player lens
Lens Cleaning CDR CD-RW (how?)
DVD Not Working
Mar 04, 2009 | Sony Televison & Video
My player cannot read any disk?
when i insert a disc it always says "No Disk"
Jan 01, 2008 | LG DN191H DVD Player
CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Jun 30, 2007 | Emerson MS3100 3-Disc CD Changer
Ordinary cd-r can't read but an mp3 for was ok
If it is just the one type/brand of disk, the drive may just not "like" that brand of disk. CD manufacturers use different compositions of the layers of the burning media, some drives just won't read some media. Try diff brand...
Dec 28, 2005 | Panasonic SL-SV553J Personal CD Player
LG DN191H DVD Player Logo
129 people viewed this question
Computer Repairing
Computer Repairing
