Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
How do I access the V-safe portion of my verbatim flash drive ... I've switched from Windows xp old computer to Windows 7 new computer and all that comes up is the public zone portion which states there is 767mb of memory .............
  • 13 Answers
SOURCE: Verbatim 1gb flash drive privacy zone lost space
In order to delete your privacy zone, you have to get the application once more. To get the software click here http://verbatim.com/support/support.cfm?open=Downloads ...ok so you will have to format your flash drive with the application, removing the privacy zone if you want, this will obiously DELETE ALL DATA ON THE DRIVE after the format has completed, you can then remove the application from you flash drive, if you still remember the privacy zone password, then all you have to do is just type it and you have acess to the privacy zone... anyone who needs assistance can contact me to semirandomjr@yahoo.com if you are confused, email me and i can also try to clear it up for you. MAKE SURE THAT YOU CHOOSE THE CORRECT PRIVACY ZONE APPLICATION FOR YOUR FLASHDRIVE
Posted on Sep 19, 2008
SOURCE: how do you access the private zone when there is no icon to do so
Go to http://www.verbatim.com/support/support.cfm?open=Articles and download the V-safe software then install on your flash drive. You can unlock it using old password
Posted on Jun 18, 2009
SOURCE: Verbatim portable hard drive not recognized by XP - works in 2000
Try it is different USB port of your PC. It worked for me.
Farhan
Posted on Nov 10, 2009
  • 630 Answers
SOURCE: my 8 gig verbatim usb drive only letting me use 767mb
You sure that it's not 7670MB? If not check that there isn't another partition on the drive.
Posted on Nov 20, 2009
Damilare
  • 358 Answers
SOURCE: I've just bought a 250GB
Even though it is possible that your USB hard drive is corrupt, but
before you finally conclude, try out these few troubleshooting
steps.
First of all, it is possible that the USB port that you are using is a
USB 1.0 port, which has a lower voltage not enough to
power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a
USB 2.0 one (Just keep Checking all the ports one by one in case
you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in
an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy
a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Meanwhile, before you try out the second option, test the drive on
a friend's system, that you are sure has a very good system, with
USB 2.0 port.
If after trying out all these, the USB Drive still doesn't work, then
I'm afraid, the drive might have been bad/spoilt.
Kindly keep me posted about the problem and let me know how it
goes
Hope this helps you out.
Thank you for using Fixya
Goodluck
Posted on Oct 07, 2010
I AM NOW WITH WINDOWS SEVEN AND CAN'T OPEN MY HARDDRIVE TO VIEW WHATS ON IT, HOW CAN I ACCESS MY PICS AND FILES, IT WORKED FINE WITH MY OLD COMPUTER WINDOWS XP
Do you have access to your old XP machine, the easiest way for you would be instead of tinkering around with drivers, filesystems, recovery programs. Boot up your XP machine, map a shared drive to your new windows 7 computer and copy the files over. If you do not have access to the old computer, let me know.
Jan 25, 2015 | Computers & Internet
Windows 7 can't access hard drive running Windows XP
The most common reason is that the physical hard drives are not "Pinned" correctly. If you did not move a jumper pin or know what I am talking about, then this probably applies to you. If you would like instuctions let me know!
Jun 15, 2012 | Gateway Dx Series Dx4822 Dx4300 Dx4320 Top...
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
Please insert disk
Insert the disc that came with it ( if no disc came with it then it should not need one.) If it still insists it needs a disc go the verbatim website and go to the drivers/software/downloads page, and select the model of the pendrive and download the appropriate drivers ( your operating system etc XP or windows 7)
Plug it into the usb port and go to 'my computer' there you will see the drive most likely named verbatim, double click to open it.
Then open a new window and find the file you would like to transfer, simply click on it and drag and drop it into the usb drives window and wait for the file transfer to finish.
Jan 06, 2011 | Verbatim ® Store `n` Go USB Flash Drive,...
How to load backup from one computerWindows XP (now on Verbatim USB 320) to a new computer running Windows 7
This is not really a solution but for information. There is no direct upgrade path from Windows XP to Windows 7. So, unless you have a compatible program installed on your Windows 7 PC, you will not be able to import a backup from your XP PC. (To My Knowledge).
Oct 16, 2010 | Verbatim External, USB 2.0, 750GB...
New computer with windows 7. old one is xp flash verbatim drive is not recognised.
File Format is the same... should work.... try the USB Ports in the Back... or it maybe a 1.0 Flash Drive that is not supported anymore.
Dec 28, 2009 | Computers & Internet
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
938 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
